JR & European Frequencies
PA
I will soon be moving from the USA to the country of Luxembourg. It is my understanding in that part of Europe 75mhz is not used but rather 40mhz.
I am currently using a 75mhz XR3 FM radio and would like to use the same or similar in Europe. Does JR make the XR3 or something similar in 40mhz. If not, what would you suggest?
Roger
Roger
Roger,
When you get there, there should be a JR service center that should be able to convert the XR3 to 40mhz provided that they have the parts required. I believe that Graupner should be the service center that you would deal with from there.
