JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
3810 adt -- resolution
Old 11-12-2002, 01:17 PM
francois118
Default 3810 adt -- resolution
Danny,
people talk about 1024 resolution on their pcm TX. Can you please explain this concept to me. What different resolutions are there and what is the result ? What is the resolution of the 3810 adt pcm ?
Francois
Knowledge will set you free
Old 11-12-2002, 01:56 PM
dsnyder
dsnyder's Avatar
Resolution is the number of steps the servo will take in its range of motion. JR currently has 2 different systems, each of which the 3810 or 8103 will do. The older generation is ZPCM, which is 512 resolution, or 512 steps in the servos travel. The newer generation is SPCM, which is 1024 resolution, or 1024 steps in the servos travel. Which you will use is determined by the receiver you have. SPCM will make more precise servo movements since the steps it takes are half the amount of rotation compared to ZPCM.
Old 11-12-2002, 02:11 PM
francois118
Default resolution
Danny,
thanks for your quick reply.
Francois
Old 11-12-2002, 03:30 PM
dsnyder
dsnyder's Avatar
No problem! If you have any more questions, please let us know.
