10X mode1 to mode2 change
RE: 10X mode1 to mode2 change
I phoned them, they advised me that it can not be done.
I have already changed the springs, gimble stops, pots, and trims over to mode two configuration. It seems to all work correctly using my sim, and control the servo's on the heli correct for mode 2.
As is, I really have a mode1 with the gimbles and trimmers in Mode2 positions, is this what mode2 is or is there other requirements ?
From what I can tell, the same value pots are used for all 4 gimble channels, so changing them shouldn't cause any problems.
I am an electronics technician, but have no experience with RC hobby radios, is there any software changes requires ?
Damian
Damian
ORIGINAL: dsnyder
I'm not sure with overseas systems. If they say it can't be converted, I would assume they were right.
hi
send me your email and i show you how simple is to switch feom mode 2 to 1. this radio is one of the simple because they use connectors on board and not soldering the pot wires directly.
[email protected]
have a nice day
Mirco
[email protected]
have a nice day
Mirco
