10X Fast Charging
AL
10X Fast Charging
Danny I have fast charged my 10X and have blown the fuse in the battery both times. I guess my question is can you field charge the 10X without blowing the fuse.
10X Fast Charging
Yes, you sure can. It is a 5 or a 10 amp fuse in the battery pack, but I would stay around an amp to an amp and a half for a fast charge rate. Make sure the black insulating ring on the charge jack from the charger is not damaged or worn, and that it is preventing the center pin from contacting the outside of the plug. Also be sure that your polarity is correct for JR and it should work fine.
