Loose screw JR-9303
WI
Loose screw JR-9303
Hi
I was putting my 9303 back in its case after charging and I heard a rattle in the case. I shook the thing and yup sure enough something loose in the case. I removed the battery and the module. shook it some more and this screw came out. I took a picture of this screw I was hoping it might be identified. Ive had the radio just over a year no troubles. Thank you for your help Im hopping the person who assembled it dropped one and it got lodged in there and just now fell out. { Wishfull thinking }
RE: Loose screw JR-9303
ORIGINAL: bluemagic98
WI
Well I hunted for any whole missing a screw and found none. It looks like the screw they use to hold the throttle tentioner down but that screw is there however that one is loose but im assuming they dont want that one nailed down as to allow for further adjustments. I did check the base of my antena as the other person had said that was my first assumption. If this screw isnt from under one of the circuit boards then its a adjustment screw that got missplaced durring assembly there are very few machine thread screws in this radio. Thank you for your time. By the way its a very very nice radio.
