? about xp6102
? about xp6102
i have a xp6102 we used the wrong charger on the transmitter. not the screen is all dark when powered up and you cant read anything . what can i do do i have to send it in . Thanks Keith
RE: ? about xp6102
Okay, first thing you need to do is take the nattery out and fit a known working one. Check the fuse on the 6102, it is located on the switch PCB underneath the RF PCB.
Hopefully this is all that is blown, if the fuse is okay, power the set up and keep your fingers crossed.
