setting up throttle switch
FL
I am using an 8103 radio. My DA-50 seems to stall out at low idle while doing inverted spins. They say I need to either bump up the throttle after take off or put the throttle on a switch. I know I use Thr-Thr on one of my mixes, but how exactly do I complete the set up where I can hit a switch to bump up the idle after take off? If you can give me detailed instructions, I would appreciate it.
Dave
Dave
RE: setting up throttle switch
Yes, you would just need to set up a throttle to throttle mix, assign the mix to the switch of your choice, and set the rates of the mix as needed to get the movement required.
