8103/.60 UltraStik Aileron/Flap Problem
AZ
Good Morning Danny:
I have an 8103/Hangar 9 UltraStik .60 combo. In aileron to flap mixing, is there any way to adjust the flaps individually so that they will have the same travel as the adjacent aileron? When I activate the Mix Switch, the flaps move in the correct direction with the adjacent aileron, but the travel of the flap is different from that of it's adjacent aileron.
I have attempted to correct this with the [AIL-FLAP Mix] rate without success.
Thank you for your assistance.
RE: 8103/.60 UltraStik Aileron/Flap Problem
Are they moving close to the same amount or are they far from the same? If they are close, that is fairly normal, the flaps are set to have quite a bit of down travel, so usually the throw is limited in the up direction which affects the flaps travel as ailerons, usually limiting throw a small amount.
AZ
Good Morning Danny:
Thank you for your prompt response. They are close. I will live with it. Thanks for a great product and your usual great service. My best to everyone at JR and Horizon.
