It is normal ???
It is normal ???
Hi!!
I just got my new DX7. and i finsh to set it up on my old H9 Funtana. I have notice when i put the TX a few centemeters (very close ) from the plane my rudder and elev servo makes some noises (they shake) . When i go back like 10CM from the plane or when i do a range test its ok no noises.
is that ok ???
is that ok ???
RE: It is normal ???
Yes, this can happen, it is called swamping the receiver, basically the receiver is being overpowered. As you have noted if you take a couple steps back the problems go away.
