Dual elevator problem
when I setup the dual elevator servo's they are sometimes not the same throw as i left them and must go back and reset the travel. It seems the aux 3 half is always higher than the ele half. I usually use code 22 d elev. I have a JR 10X about three years old and using JR DS 8411 servo's.
Go to code 17 and inhibit the aux 3 channel if you have not already. That should take care of it. If not, let me know and I'll try to run through a couple other possibilities.
