X9303 Questions
TX
X9303 Questions
What all differences between the XP9303 and X9303 are there?
I see that the Timer is much larger, Very nice!
And Modulation is missing from the menu, Which i Expected but I noticed in the manual it specifies that the Current drain is 180 Ma in the DSM2 mode and 280ma in the DSM1 mode, I see no way to set which mode it operates in so how could this be since the recievers dont transmit also?
I searched the manual and i see no way to set DSM1 or DSM2 modes, Understand?
So how can the transmitter know which mode, So how can the Current drain change?
Thanks in Advance
Thanks in Advance
RE: X9303 Questions
The timer display is it in terms of the programming or what you see on the screen. DSM 1 or 2 is determined by the receiver you are using. The AR6000 and BR6000 are DSM1, all other receivers are DSM2, this is set during binding. You don't have to do anything or worry about this, it is handled internally.
TX
RE: X9303 Questions
Timer display is much larger on the screen is what i meant.
So the Spektrum stuff is Two Way communications, Is that only during Binding?
Dave
Dave
