Default settings
Location: Bishop\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'s Stortford,
Default settings
Just started setting this up or at least going through the manual.
Now, after the wing type has been set to flapperon because there are two servos if I hit the flap switch then I get the ailerons to move unequal amounts in pos 1 and 3
I know they are set for 100 and 100 in those positions but if I adjust for normal as 0 and land as 50 what happens is this differential in end points or throw adjust.
I cannot help but feel I am missing something.
RE: Default settings
This was on the X9303 forgot to say and anotehr think if I inh flaps then obviously the prob doesnt exist. I have reset all data and started again with the same results
The direction of the servo also is for instance the same when as two ailerons but when flap is applied one goes one way and the other goes in the oppposite direction.
One thing I have noticed that with no flaps or inhibited so itsw just nice and simple the aileronL and aileronR both move in the same direction - not having touched any reversing switches. Should they? or is part of the problem I am geting when flaps are selected?
I think that because I was monitoring on the TX I was simply confused, After trying my DX7 the throws seem to go in the very same directions and the throw "limits" at end of stick movement to prevent overdrive of the servo.
Hope thats right anyway. If so probelm solved - or no problem as the case may be!
