Center the TRIM. DX7
NV
Hello,
I got my new DX7 and have a question regarding TRIM.
Usually during the first couple of flights you fine tune the TRIM. When everything is fine I would like to keep the setup but re-center the TRIM.
How do you do that?
How do you do that?
Location: Bishop\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'s Stortford,
RE: Center the TRIM. DX7
Are you after having zero trim variation set on the tranny? If so you can either use good old mechanical adjustment on the model - prefered - or you can use the sub menu trim on the tranny which will leave the trims (that you can see on the tranny screen at zero - Not prefered as it reduced throw in one direction of servo travel.
Not sure I totaly understand what you mean but hope this helps.
The only way to do it would be to adjust the sub trim to match the trim, however there is absolutely no need to do this. The trims are automatically stored for every model.
