X9303 + R921 Receiver WIERD BEHAIVOR.
I ordered "a bunch" of R921 (AR9000 in red) to replace my old AR7000 receivers.
And I get some VERY strange results when binding.
Steps taken:
1. Put in the bind-plug.
2. Turn on receiver, all leds blink (3 of them, 2 in the main + satellit)
3. Turn on radio with button pressed.
4. Got solid light on all 3.
5. Remove bindplug.
No it gets interesting.
In detail.
If I turn on my radio, plug in the battery (electric heli) it boots up ok, 3 solid leds.
But If I had my radio previous running, disconnected power to the receiver and put the power back up, the satellit starts to blink (not binding blink, but slower), I get the system running (can move the servos etc), but the satellit keeps blinking, there is two solid lights on the main receiver.
I have the same behaivor on 4 receivers, is this normal? if not, is there a way around it? Im totally stumped, the R921 that came with the X9303 dont do this.
anyone else seen this?
Steps taken:
5. Remove bindplug.
In detail.
RE: X9303 + R921 Receiver WIERD BEHAIVOR.
an update/addon,
All my 7 new R921 does the same, However, If I use the satellit from the old AR7000 or older R921 or AR9000 then it doesnt do this.
Bad batch of remote receivers or has they been redesigned so this is part of some "feature"?
Phew, got the word from Paul Beard that this is normal, new feature that shows it used "Quick Connect" feature.
