Binding problem
I had a little problem with my DX7 so I sent it in to be checked out. It came back today with a note saying they reprogramed it. So, I had to reinstall all my settings. Now, it won't bind with either of my planes.
To rebind it should I unplug all the servos out of the reciever?
Rod
Rod
I assume you mean that it is not linking with the aircraft? If the system was reset, then the receivers will need to be rebound. You don't need to unplug the servos to bind.
Binding and linking are 2 different things. Are they not linking (linking to the transmitter that they have been bound to) or not binding with the transmitter when you put them in bind mode?
