Spektrum DX 3.0 Cuts off intermitently
Hi,
Just purchased a brand new Spektrum DX 3.0 unit. I have determined that the transmitter unit is glitching i.e. My electric boat is cutting out intermittently on the lake. I have used the supplied receivers with another Spektrum unit that l own which work well with no cutting out/glitching. I have also tested the Spektrum DX 3.0 unit on two other boats with their own receivers resulting in the same problem,
What l wanted to find out is if there are any settings that l could adjust to fix this issue or is it a simple case of sending this back for repair?
Thanks in advance.
Thanks in advance.
RE: Spektrum DX 3.0 Cuts off intermitently
The only things I would recommend checking would be to range test on the ground with the model stationary to see if you can find any problems with a particular component to narrow down the issue, and also check all batteries, switches etc. From there, if the problems persist, send the system in for a check up.
Hi Danny,
I have perform distance test which worked without any issues. I had already placed brand new batteries into the Spektrum DX3.0 unit.
I live in Australia, l bought this unit brand new from a seller on eBay:
http://cgi.ebay.com/ws/eBayISAPI.dll...:X:RTQ:US:1123
Do you have a repair outlet in Australia? If not, what is the pocess for sending this back for replacement/repair?
Thanks Danny, please advise.
The only Spektrum service center is in the US.
You can download the service center checklist and return with your repair from this link:
http://www.horizonhobby.com/Support/...t/Default.aspx
