JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
JR PCM9X On 2.4 Can it be done
Old 11-25-2009, 08:19 AM
Aceface
Default JR PCM9X On 2.4 Can it be done
Hi there all, I have a JR PCM9X Radio and was wondering if anyone knows if this radio can be upgraded to 2.4 and whether it works OK.
Old 11-25-2009, 08:51 AM
BuschBarber
Default RE: JR PCM9X On 2.4 Can it be done
I believe in the US, the XP9303 is the equivalent, or close to it. I have an XP9303 with a Spektrum Module and it works fine.
Old 11-25-2009, 12:44 PM
Red B.
There are several alternatives available for upgrading a PCM9X radioto 2.4 GHz. Manufacturers that sell 2.4 GHz modules for JR PCM9X are for example Assan, Corona, Graupner IFS, Weathronic, JETI.
Old 12-01-2009, 09:38 AM
MIKE1000
MIKE1000's Avatar
Here in the UK I hav been using a JR 2.4g module in my PCM 9 Tx for over 1 year now with an RD 921 Rx with 2 EA 101 satelite
Rx's. It also works well in an 9303. You will be very happy with this setup. regards Mike T. Bromsgrove England. [email protected]
Reply to ACEFACE.
Old 12-01-2009, 09:42 AM
MIKE1000
MIKE1000's Avatar
Reply to ACEFACE.
Old 07-13-2010, 10:02 PM
FNQFLYER
I have just purchased and installed a Spectrum 2.4 gig conversion for my 9 X 11. The local distributers will no longer import the JR module conversion (to dear). I have seen the Spectrum to JR conversion work well with one very big proviso, do not keep changing the modules between (here 36mhz) the FM frequency module and the 2.4 gig module as the pins will wear out / distort resulting in lots of grief
Old 08-19-2010, 07:45 AM
jfcgnv
I'm confused. I thought that you could only use a 2.4 module with a PPM (FM) TX. If I'm not mistaken the PCM 9 is only PCM and the modulation is 512 (Z and G ). Are you saying that there is some after market 2.4 modules that will work with the JR PCM9 TX?
Old 08-19-2010, 08:24 AM
BuschBarber
As was stated above, I believe the PCM9 is similar to the XP9303. Each Model Memory has a parameter, called Modulation, that can be changed from PPM to one or more PCM types. I have had an older Futaba Conquest radio that was PCM only, but it did not have RF Modules like the 7, 8, and 9ch Futaba radios. My first JR radio was an XP8103. It used RF Modules and had the Modulation parameter.
Old 08-19-2010, 08:30 AM
jfcgnv
It is my understanding that the JR PCM9 is NOT switchable from G and Z PCM to either PPM or S PCM. Am I Mistaken? If it can not be switched from PCM then I don't believe the 2.4 Module of any manufacture will work.
Old 08-19-2010, 09:20 AM
BuschBarber
Here is a link to the PCM9X manual and it clearly states that Modulation can be changed from various PCM types to PPM.
http://rc.runryder.com/helicopter/ga...9X_English.pdf
Is this the same radio?
Old 08-19-2010, 09:23 AM
BuschBarber
Here is an ad for the PCM9X II.
http://www.modelflight.com.au/rc_mod...o_pcm9x_v2.htm
It also has a Modulation parameter.
Old 08-19-2010, 01:16 PM
jfcgnv
We are talking about two different PCM9 TX's. The one I am talking about is the Single stick PCM9 that was available in the early 90's. It was also sold by Circus Hobbies in las Vegas under license from JR. This PCM TX was only 512 and not switchable. Although the 2.4 module will slip right in it will not work.
Old 08-19-2010, 08:49 PM
BuschBarber
Sorry for the confusion!! Just trying to help!!
Old 08-23-2010, 08:40 PM
FNQFLYER
As I said before I have a 9X 11 and it works well (to well with all the bits and pieces) with my spectrum conversion as do 2 similar conversions that I know about
