DX 7 troubles
Guys I have a DX 7. My problem is when I turn the tx on and the rx, it binds ok but I cannot get my servos to move. They just chatter very fast. I've binded it several times and no luck. I've never programmed a radio for a plane so is it possible I have INH something in the radio or something needs to be turned on? Any help would be appreciated. I made sure that I had my radio on the correct model when I did the bind.
RE: DX 7 troubles
Let me first establish whether you're binding or linking.
I appologize in advance if any of this is old had but its your first post and I have no way to gauge your experience level. Binding is the process of using the bind plug (rx) and bind button (tx) to pair them. After that you remove the bind plug. Now when you power up the system you're linking a system that you previously bound. Seems you know about model match so we won't get into that. Another thing you may or may not know is that you should be a couple of feet away when you're linking, and if you're having trouble make sure to step away from metal shelving, metal table tops, and or pickup truck beds or the like. If after that you're still having issues, remove all servos and see if the system links up with solid lights. Then power down both and add servos one at a time and see if you have a servo or something shorted. While troubleshooting remove anything from the reciever end but a battery and servos. No extensions, switches, or speed controllers and make sure the reciever battery is fully charged. |
RE: DX 7 troubles
Make sure you have all the remote receivers attached to the base. If you don't, it won't be telling the servos what the transmitter is saying. It's part of the failsafe mechanism.
Andy |
RE: DX 7 troubles
I'm trying to trouble shoot it now. I'll try the servos one at a time. Also my motor (Neodym NEO 450-1120) starts beeping as soon as I connect it to my esc. (Neodym NAO-40A ESC). It beeps wether the esc is hooked to my rx or not. I've never heard a brushless motor beep before. If the esc wasnt getting signal from the esc would it also cause my servos to not work?
RE: DX 7 troubles
I've just tried the rx by itself. It doesnt matter what servos I try, nothing works. The rx is an AR7000. The lights come on solid and all but nothing happens.
RE: DX 7 troubles
Well I figured it out. It was a combination of a bad esc. and a bad rx. It really had me pulling my hair for a minute. thanks guys.
RE: DX 7 troubles
ORIGINAL: OuttaControl Well I figured it out. It was a combination of a bad esc. and a bad rx. It really had me pulling my hair for a minute. thanks guys. |
RE: DX 7 troubles
Does your DX7 have the 11 Ms fast rate available?
Perhaps there is a compatibility with the servos. A typical analog servo expects to see a 20-22Ms rate <br type="_moz"/> |
RE: DX 7 troubles
Nope
