JR 9303 Tx
Memory problem with TX, I can select the required model memory ok but after flying when I turn the Tx off then back on to fly again, the Tx reverts to the last model memory programmed not the one I used for the last flight.
Can any help with this problem |
It is worth calling Horizon for help...
Originally Posted by stuartt
(Post 11768256)
Can any help with this problem I bought a DSX9 (JR9503) and it had a memory problem that it would not save anything after power off. I ended up returning it and buying another. <br> http://www.youtube.com/watch?v=NvIQNVTu5Xk |
Returning to Model 1 each time
(Post 11768533)
Turn it on again and see if it remembers the trim positions or it may reset them to zero as mine did. Give Model Flight a call in Adelaide, www.modelflight.com.au They have always given me excellent service. |
Hi;
Something is wrong with the Flash memory...it should remember the settings...and model....it does need service. Codimasta |
