K140 gas start
My Feedback: (46)
K140 gas start
I just received a K140 gas start. When I put it on the test stand and ran it, the first start was fine. Then the next few times I tried to start it, the turbine would ignite the gas and then not accelerate to get to the fuel ramp mode. It acts like it is not getting enough gas to get the temp up. What should I do? I am using propane butane mix, Thanks George
RE: K140 gas start
Another couple of things to check, connect the HDT and make sure the temp is rising during the gas ignition phase....before it switches to the fuel, if the temp isn't rising enough it won't get onto the pump ramp.
Also check the rpm during the same period, if it's erratic and varying by a large amount it will cause start dramas also.
Cheers,
Smithy.
Cheers,
Smithy.
My Feedback: (46)
RE: K140 gas start
Ok here is what the turbine is doing. It will ignite on propane butane mix then will not bring the temp up above 75c. If I turn the bottle upside down and get a little liquid in the line it will get the temp up and do the start to kero like it is supposed to do. I am using Colman butane propane mix that you can buy at Wal-Mart. Works just fine on my other 6 turbines (wren Jet cat).
Rider I will try that right now.
