DX9 issues
DX9 issues
Used my buddies DX9 for my maiden flight in preference to my DX7. Fine but for one problem where could not shutdown the engine. Throttle stick and trim down to minimum and it still kept running. So had to turn the fuel tap off. Put trim and throttle stick back up and it wouldn't go to cooling. Had to unplug ECU and RX batteries and reconnect before it would good to cooling. Went through learning program few times and made no difference. Any ideas? Anyone else using a DX9? I fiddled with throttle end point adjustment and sub-trim but no change.
RE: DX9 issues
...can I just ask what you mean on idle down and up. There is an idle bottom, middle, and top.
Is idle down the bottom position and idle up the top position?
RE: DX9 issues
ORIGINAL: DominicM
Cheers,
Smithy.
RE: DX9 issues
Ah, on the Data Terminal. Misunderstood. Thought George meant on the Transmitter. Discovered that the value on the DT was 0% at throttle min and trim max. Adjusted throttle sub-trim until it came up to 16% on the DT. Will do an engine start tomorrow and check it works as it should. Thanks all for your help.
RE: DX9 issues
Tested today and engine worked perfectly so thanks again.
Do have another question. To start I put trim up to max, throttle up and back to idle, hand terminal reads 'Burner On'. I then have to throttle up and back down to get the engine start. Is this normal?
RE: DX9 issues
ORIGINAL: DominicM
Thanks to George and Brett for the earlier support!
Cheers,
Barry
RE: DX9 issues
OK. Will do that next time. Fairly sure I waited something like 10 seconds and nothing happened and as soon as I went full throttle again it started. I'll wait longer and see what happens. Cheers.
RE: DX9 issues
Ahhh OK. And there was me thinking it would start up as quick as all my EDF jets. Going to have to learn a little patience aren't I.
