KingTech Turbines International Barry is your host and will help you with all your Kingtech questions and concerns.
K-100G on 7.4V
Old 08-19-2013 | 06:02 AM
Default K-100G on 7.4V
Hi, will I damage the ECU if I am running a HV setup?
Can't seem to find any threads on this.
Old 08-20-2013 | 02:49 AM
number27's Avatar
ECU should be running a 9.9 Life Battery setup so I believe NO. check your manual for voltage requirements of ECU. My 170 and 140 both run Life 9.9 ECU batts.
Old 08-20-2013 | 04:16 AM
Sorry if I wasn't clear with my question.
ECU I'll be using 3s LiFe. What I meant to say was I wanted to run 7.4v in my rx line for receiver and servos. Will the ECU be able to handle 7.4v from the throttle channel?
Old 08-20-2013 | 04:39 PM
Chris Smith's Avatar
Recent versions of the Xicoy ECUs are rated for 4-10Volts on the 3 wire receiver input line. I can't confirm the current V10 ECU used with the 100G is the same, but it is likely.
I have at least one fellow jet flyer using a K170 and a HV receiver dual battery system (Lipo). I do not believe it is regulated at all. I'll check.
Barry should be able to confirm you are good with 7.4 from the receiver to the ECU.
Old 08-20-2013 | 05:23 PM
Thanks for your reply Chris.
Do let me know when you have more information from your fellow flyer on the HV setup.
