KingTech Turbines International Barry is your host and will help you with all your Kingtech questions and concerns.
100G - Lower its thrust
Old 10-25-2013 | 03:17 AM
Default 100G - Lower its thrust
Hello,
I have just installed my Trusty 100G on a Falcon 120, i do need to lower the thrust to approx 18lbs,
what is the recommended path for this?
CAn the RPM be lowered by reducing the throttle travel on the TX,
also what RPM level should be ok for the above thrust value.
Any help is appreciated, Thanks in advance.
Cheers
Ravi
Old 10-28-2013 | 02:56 PM
Dr Honda's Avatar
It depends on what mods you've made on your Falcon. if you beefed up and supported the tails... Glassed the wings... and suported the engine mount... then run it at 100n. I have a buddy who runs one at full power with a JC Rabbit... and it is FAST !!!!!!
BUT... if you want to take it down to 18#'s... I would say to take off 9K ~ 10K rpm's up top.
Old 10-29-2013 | 12:02 AM
Thanks tony, have sheeted the wings and have supported the engine mount,
so i guess will run the way you say, i can always throttle back.
cheers
Ravi
Old 11-08-2013 | 06:15 AM
My Feedback: (18)
cheers
Ravi
Yeah just manage that throttle stick a bit on the flat and level Nothing like having all the vertical in the world on take off and when you want it !
