K-210 on 2s lipo
K-210 on 2s lipo
Hi guys,
I have a plane with a turbine battery pack in a place I'm not willing to reach.
Can I fly my K-210 with this battery?
Will the only downside be the number of starts?
I need to change something on the ECU to use this battery?
Thanks in advance
Gabriel
Thanks in advance
Gabriel
My Feedback: (33)
The ECU will not let it start due to low voltage. If you max charge it ( I can't remember it lowest it will work at) and it does start then I am sure it would flame out very quick due to reading low voltage. All of the G model kingtechs require a 3s life battery.
Sorry that it is a lot of trouble to change it.
[/QUOTE]
Since when is this a requirement?
I had a K140G that i used a 5000Mah 2S 7.4 volt 45C Lipo pack on with out any problems and i could get 6 flights on it before recharge.
[/QUOTE]
Gabriel, if you don't mind using only the top 30% of the capacity before you get failed starts while risking flooding the engine towards the end of the 30% capacity. We find that 3S LiFe is just a way better way to go about; it's flat discharge curve translates to less work for the ECU and therefore greater reliability. Further, the engines are already adjusted by the factory using 3S LiFe, with 2S LiPo, you may have to increase ignition pump pw in the start menu. Bottom line, you could probably make your 2S LiPo work for you, but it's not for everyone.
Barry
Barry
My Feedback: (9)
While if its a good battery it will start on a 2Cell lipo a A123 LIFE is recommended. I have seen so many people report start problems but they are using a 2 cell lipo. Switch to LIFE and all is good. Gabriel if you battery is hard to get that's all the more reason to change it so you don't have to worry about a fire hazard with the lipo. Saw 2 lipo fires last year at Kentucky jets in the plane. I would get rid of it.
Also keep in mind the start is when the turbine gets the hottest and its very hard on the turbine. I would want the starter working as hard as it can on good voltage so the start is smoother and cooler. That means less wear and tear on the motor.
LOL i see Barry replied at the same time. What he said!
Barry
Barry
With a 2s lipo 3000 can I make 3 flights before recharge?
Should I increase pw pump if I have some lost starts? Shoud I increase to how much?
I will change to life 3s. Just can't do it now.
Best,
Gabriel
Regards,
Barry
My Feedback: (41)
Hey Barry, 'nuther quick battery voltage question for you; our favorite person has indicated on the thread above this one that the ECU doesn't get it's power from the ECU battery but from the PE and that a max voltage of 6.6 should not be exceeded. I've got the three cell LiFe battery from you guys for the ECU on my K210G, but the model is setup to run unregulated LiPo's, can you clarify the question having ro regulate power to the ECU which I'm guessing would be through the throttle connection?
