K-160G2 GSU Problem
Doesn't sound normal to me..
Double check your connection.
Also make sure you have 6 volts going into your ECU from your RX. Suggest to run 2 power cables into ECU.
The GSU has a micro processor that likes 6v or over.
This ONLY affects the GSU NOT the ECU while flying.
