K-160G2 idle
K-160G2 idle
How low can I put the rpm setting and still be safe form flameout? At 37k I have too much residual thrust when landing. Any help please. Kelly
My Feedback: (9)
Hello Kelly
What kind of plane? Any way to increase drag on it like adding more flap?
We have been helping people with flameout issues only to find out they turned down their RPM in the ECU to a lower number causing the flameouts. I would try other options if possible before adjusting Idle thrust. You might be able to turn it down to a safe number on one day then the weather changes and the number is not safe to use and may cause flameouts.
