Fuel line size
NJ
Fuel line size
I have a k-80 I am putting into a xcalibur, its the older style that uses the external start and run solenoid valve's, What is the correct size fuel line to use so it locks into the fuel connections at the turbine, would it be 4mm or 1/8", not sure, old fuel line is clear, or should I say was, but I cant make out what it says on it.
My Feedback: (53)
