Kingtech 142G+ low RPMS
Kingtech 142 G4+ low RPMS
I have a K142G4+ with 10 hrs on it that came with the plane. Was running perfectly for the previous owner. On test runs, I am only getting about 120k RPM at full thrust. Max is 142k in the book. I tweaked the Pw up a bit, and the result is a LOSS in peak RPMS. I can see what the other guy was getting in the Summary report on the GSU, which was full rated thrust (142k+). I cannot seem to get the Pw to go above 400ish. Any thoughts? Pump is the 600BL.
