Paint for monokote/ultracote
My Feedback: (45)
Building a tf spitfire and covering it in film. Would like to use ultracote if I can find the right color grey, question is what is the best paint to use(olive drab). Lusterkote is out of the question since it's no longer made, and I remember the older stuff being horrible.
RE: Paint for monokote/ultracote
I know that Aero-Works have their models covered in Ultracote. They also have beautifully matching painted components. You might get lucky with a call to them.
LustreKote is still being made. My local hobby shop still stocks it and you can buy it online. They have narrowed the color selection down to not very many though.
Thats the downfall of it, they do not make olive drab paint so you wouldnt be able to find it (made by lustrekote) anywhere. Here is the monokote website with the list of paints they make. Its very limited in selection with only red, yellow, cub yellow, white, black, insignia blue and clear.
http://www.monokote.com/lustrekote/lustrekote.html
http://www.warbirdcolors.com/raf_home.asp
just carefully scuff sand / steel wool 000 your monocoat, ultracoat, and paint with this latex based paint. it comes with a fuel proofing catalyst to protect against glow fuel. Look at my models, the Thunderbolt. Nice colors, and they cover well, last very well.
My Feedback: (45)
ORIGINAL: bingo field
TX
Hi Bingo Field. Thanks for the great advice, also, you have an Excellent photo gallery on your site.
Question - I am finishing a GP p-51D, and I'd like to paint portions of the engine cowl in a black/yellow checkered pattern with off-brand spray paint that I picked up from Lowes. To ensure that the paint is fuel proof, I am planning to put a coat of Lustrecoat clear coat over it. I didn't want to purchase additional cans of Lustrecoat because they are too expensive, so I went with a couple of cans of off brand spray paint. The question is, will this method produce good results and be as durable as using Lustrecoat, or should I not try it and go buy another can of Lustrecoat. While I am concerned about the cost, I don't want to cut corners on the paint scheme.
hafidy
hafidy
Go to the 'show your stuff' forum on RCScalebuilder.com and look at the SIG Skybolt thread there. The method to paint Monokote is outlined there in great detail. You can 'lurk' for free but you have to create an account to do so. Good luck.
I have used Lustercote over spraycan paint, you just have to mist and I do mean mist, as in as lightly as you can and let dry between coats on the first few coats to keep the base paint from crinkling.
My Feedback: (14)
Don't paint plastic film coverings! It is going to come off in sheets. What do you do when the covering loosens up and has to be retightened?
If you HAVE to use iron on plastic film, try using laminating film that is applied with a low temperature. It is a boatload cheaper than the hobby coverings and it can also be bought with a matt finish, saving you all of the effort of scuffing up the finish.
It can be bought in several different thicknesses too and it holds up as well to fuel as the moneykote coverings that we are all familiar with. A huge roll of this stuff is ridiculously cheap. I know a fellow that built a lot of models. He was/is an engineer and he prototyped a lot of his designs as cheaply as possible, hence his discovery of using this film as covering. I wish I could remember his name - damn it! Anyway, he was looking for a covering that would last a dozen flights or less. He didn't care about longevity. He said he was surprised that the laminating film held up at least as well as the monkeykote coverings. If you can look up the old newsgroup rec.models.rc.air, and then search for laminating film, I'm sure that you will find enough written testimony by Brian (last name eludes me, but it was Italian sounding) to convince you to at least give it a try. Good luck.
Ed Cregger
Ed Cregger
Ed,
Is this what you are talking about? It says it is thermal - available in 1.5 or 3 mil cheap. http://www.laminationdepot.com/Schoo.../products/104/
They have some 27" X 250 foot matte finish rolls. You need to buy 2 rolls @ 58.89 each roll or 117.78. That's the equivalent of 83 6' rolls of Monokote! I want to try some but not at $120 for a trial use. http://www.laminationdepot.com/PRO-3...nfo/40-272-1C/
Course looking at $1.44 each for an equivalent to monokote looks pretty good.
John
John
My Feedback: (14)
ORIGINAL: JNorton
Ed,
They have some 27'' X 250 foot matte finish rolls. You need to buy 2 rolls @ 58.89 each roll or 117.78. That's the equivalent of 83 6' rolls of Monokote! I want to try some but not at $120 for a trial use. http://www.laminationdepot.com/PRO-3...nfo/40-272-1C/
John
Ed,
John
Yes.
I have never done it, but Brian and his friends, plus regulars on rec.models.rc.air raved about laminating film's performance. Most didn't even paint it at all. It survived just fine without a finish!!!
Ed Cregger
