 JR Servo arm compatibility with Hitec >
Old 01-27-2011 | 08:45 AM
Default JR Servo arm compatibility with Hitec
Does anyone know for sure if this servo arm (<span id="prodTitleBrand">3D XL 1/2 Servo Arm 4-40: JR</span> <span id="brandName" sizset="378" sizcache="16">byHangar 9</span>)will fit onto a Hitec HS5645MG
Old 01-27-2011 | 09:21 AM
BarracudaHockey's Avatar
Default RE: JR Servo arm compatibility with Hitec
Probably not. You shouldn't use a servo arm thats not made specifically for your servo, they may look like they fit but will slip under flight loads.
The reason I say probably not, Dubro has high strength servo arms and they are 3 different part numbers, one for each Futaba, JR, and Hitec splines
Old 01-27-2011 | 09:38 AM
JNorton's Avatar
Don't do it.
John
Old 01-27-2011 | 09:40 AM
Thanks, now if i could just find a parts list for this build I would be set.
