Reload this Page >
Top Flite Giant P-47 Build
Old 06-10-2012, 05:46 PM
  #351
redbiscuits
redbiscuits's Avatar
Default RE: Top Flite Giant P-47 Build
No inner doors. I would have to buy a sequencer and cylinders to operate them and this project just isn't worth the added expense. I am going to put the fill valve, pressure gauge, and switches in the compartment that I made. I did epoxy the tank in the fuse where indicated on the plans.
ID:	1770969   Click image for larger version
ID:	1770970   Click image for larger version
Old 06-10-2012, 06:06 PM
  #352
redbiscuits
I thought I would point out that I will probably mount the ignition switch somewhere other than the compartment that I made. As Fabio pointed out, practicality sometimes wins over scale. I have the Spektrum 12ch. Power Safe receiver, and I will be running dual ED Nano 2300mah A123's.
Old 06-11-2012, 02:43 AM
  #353
CapeEynon
You aren't worried about having to replace the tank at any point? If it's epoxy'd then there really is no way to get it out... That was only my main concern.
I do actually remember the hatch for the fill valve etc now. I might do that as well.
Love what you did with the retract doors that is a really clever idea and it does give it a really nice scale look.
Old 06-11-2012, 03:16 AM
  #354
redbiscuits
If for whatever reason I would need to change the tank, it should pop outta there with a little force. I'm not to worried about it really. Most leaks occur somewhere else instead of at the tank.
Old 06-17-2012, 05:40 PM
  #355
redbiscuits
I managed to find time this weekend to finish up the gear doors on both sides. Now I'm ready to glass the bottom of the wing and get this baby primed up and painted.[8D]
ID:	1773177   Click image for larger version
ID:	1773178   Click image for larger version
ID:	1773179   Click image for larger version
Old 07-13-2012, 03:38 PM
  #356
Doomking
My Feedback: (38)
Doomking's Avatar
Any building updates? .....anyone?
Old 07-13-2012, 04:01 PM
  #357
TonyBuilder
TonyBuilder's Avatar
ORIGINAL: Doomking
I just got done installing a Saito 150 in a clients Cessna 182!
Old 07-14-2012, 02:57 AM
  #358
redbiscuits
I have been waiting on an air compressor to come in from Home Depot for the last two weeks and it finally arrived Monday. I'm looking forward to shooting some primer this weekend at some point.
Old 07-14-2012, 03:12 AM
  #359
redbiscuits
That's of course after I change the oil in the daily driver, fix a leaky transmission line, mow the grass, weedwack around the house, and fulfill my promise of taking the boy to the movies...
[&o]
Old 07-14-2012, 06:36 PM
  #360
Doomking
My Feedback: (38)
Doomking's Avatar
Why the compressor?
Can you just shoot paint from a can?
Old 07-15-2012, 04:47 AM
  #361
redbiscuits
The compressor I was using didn't have enough CFM to keep up with the HVLP guns I have, so I bought me one that would. I also decided to use Klass Kote epoxy paint on this and I didn't want to have pressure problems when spaying it.
I'm also going to place an order with Mirce for his finish set in 1/6 scale. Some of you might be following his Meister Scale build over in Warbirds. Although P-47's have flush rivets, I think I can get pretty close to scale with his finish set and not spend weeks burning rivets.
Here are a few photos of how Mirce's bird is coming along, Amazing!
ID:	1782019   Click image for larger version
ID:	1782020   Click image for larger version
Old 07-15-2012, 05:33 AM
  #362
JurassicJet
ORIGINAL: redbiscuits
WOW!!
HOLYCRAP!
Yeah, I'm just a little in awe.
Old 07-21-2012, 12:27 PM
  #363
redbiscuits
[youtube]http://www.youtube.com/watch?v=dsirHVvVwmY[/youtube]
Old 07-21-2012, 03:33 PM
  #364
Doomking
My Feedback: (38)
Doomking's Avatar
Enjoyed the video.
Thanks for the update.
Still wondering why you chose to shoot primer with a gun instead of purchasing Dupli Color primer cans.
At list you don't have to clean the gun when you're done.
Fantastic job, nonetheless.
Fabio
Old 07-21-2012, 04:18 PM
  #365
redbiscuits
That's kind of a hard question Fabio. I new that I was going to use a paint that was not available in spray cans going into this. So I thought that this would be a good way to learn how to use a gun. Also I wanted a good bond between the paint and the primer, I don't want any of the paint pulling up when I do the invasion stripes. I have heard of guys having problems when using can primer when they get to that stage. Also, I thought it would be a little cheaper compared to buying a single can of primer for around $6.00
Old 07-21-2012, 07:30 PM
  #366
oldtyme
where do you get the hinges you're using on your hatch doors?
Old 07-22-2012, 04:41 AM
  #367
redbiscuits
As much as I hate it, I picked them up at HobbyKing when I bought my muffler. 10 of them come in a pack for $1.49. Pretty good compared to Dreamworks or BVM. I don't like getting things from China, but sometimes a man has to do what a man has to do.
http://www.hobbyking.com/hobbyking/s...idProduct=8230
Old 07-22-2012, 06:39 AM
  #368
redbiscuits
[youtube]http://www.youtube.com/watch?v=Acp07KAKP7o[/youtube]
Cleaning up the shop and more priming.
Old 07-22-2012, 05:05 PM
  #369
oldtyme
Thanks Red.............I ordered 3 packs of them just to make the postage worthwhile. I'm sure I'll find a lot of uses for them.
Andy
Old 07-23-2012, 04:33 AM
  #370
redbiscuits
No problem Andy.
I did order Mirce's Warbird Finish Set from Mirce. I'm looking forward to getting that in the next week or so, and I will make a video when it arrives. The set comes with panel line tape and over 15,000 rivets and screws.
A bargain at $69.00+$10 shipping from Yugoslavia.
Old 07-23-2012, 05:07 AM
  #371
Edwin
WOOHOO! Another Jug. I just got back on mine. Expected to finish spring next year. I'll be converting mine to a Razorback. Can you say formation flying, Gary?
Edwin
Old 07-23-2012, 05:39 AM
  #372
redbiscuits
I can say it Edwin, the problem is doing it
Old 07-23-2012, 11:42 AM
  #373
Doomking
My Feedback: (38)
Doomking's Avatar
I'll look forward as well to see your rivets method.
I am getting tired as well to burn em in the primer as well as with the canopy glue method.
Fabio
Old 07-23-2012, 07:27 PM
  #374
oldtyme
No problem Andy.
Whoa........hey Gary.........let me know what that package looks like and how I get one. I was not going to do panel lines and rivets but that sounds like I might be tempted. More info please...................
Old 07-24-2012, 05:45 AM
  #375
JurassicJet
ORIGINAL: oldtyme
No problem Andy.
I just did a quick Google search and this is what I came up with.........
www.nsmodelers.rs/home/mirce-finish-set
Neil
