What Kind Of Glue?
KS
What Kind Of Glue?
I ordered the Tomahawk from Airsail today and of course it's on back order,but i have a question..i usally build Arfs,but couldn't find a nice Tomahawk ARF.
What will be the best glue to put this model together as far as the wood parts?
Stringers,ribs,gluing the 2 fusalage halfs,ect.
Thanks!
Thanks!
What Kind Of Glue?
Kits are mix of many glues. I use thick and thin CA to build, epoxy on wing centers, firewalls, gear blocks, wing bolt blocks, and I tend to go over all the joints with a bead of white wood glue shot out of a monoject syringe really thin, but enough to do the job. Holds the parts a long time. Never had a plane come apart doing it that way.
What Kind Of Glue?
I use Yellow Elmers about 95%. Even for wing joint and firewall. It's just so easy to work with. I only use epoxy when it must stick to plastic. Sometimes thin Ca does the trick but I hate getting it on my fingers!
Tom
Tom
