 uproar trailing edge warped >
Old 09-07-2011 | 10:21 AM
rye
My Feedback: (10)
Default uproar trailing edge warped
hi
i am building a uproar and the trailing edge is warped how can i get the warp out, thanks rye
Old 09-07-2011 | 11:54 AM
prgonzalez's Avatar
Default RE: uproar trailing edge warped
You can buy new pieces at LHS, or you can try to straight it out by wetting the balsa piece with windex and clamp it on the building board. Repeat process as necessary.
Old 09-07-2011 | 06:39 PM
My Feedback: (-1)
Depending on how bad the warp is then it's very easy to straighten it out with your covering and a heat gun. I do it a lot on ARFs for people. They often have warps in the surfaces.
