D&L Edge 540
I built this one about a year ago. Still have it. Its a good quality kit and Dennis will help you if you need it.
Now to be just a little more exact, I scratch built the fuse using D&L plans, but I bought the wing kit. I was intending to use a foam wing but that plan fell through so I bought the wing kit. Its all laser cut and top quality.
I use a Moki 180 for mine and its a good combination.
If I were to build another one, I would have someone cut a foam wing for me, such as dbalsa.com. The taper wing is fully sheeted, I know how to sheet a foam wing, but an open structure fully sheeted wing----well it looks good and flies great but I am not proud of the way I built it. If you know what I mean.
tonyc
tonyc
