 engine placement on northstar >
Old 10-26-2011 | 06:56 PM
Default engine placement on northstar
I am extremely excited to be building a northstar, i am puting a o.s .46ax with a factory muffler on it, my question is, does the muffler clear the engine pod if I install the engine upright. or do I have put it at 45 degrees? also I was debating about putting the throttle servo in the engine pod, is there room for a mini servo in the engine pod for that? if you could give me any tips or pics on the building of this plane, please share. thanx
Old 10-27-2011 | 01:42 AM
MinnFlyer's Avatar
Default RE: engine placement on northstar
I have my engine upright - no muffler issues.
And, while I have not done it, I have heard of people using a mini servo in the nacelle - and if I ever built another, I would at least attempt it.
I would even try to put the elevator servo back there too!
Old 10-27-2011 | 09:25 AM
if I put the elevator servo in the back, would you put a mini servo or a regular size servo? wouldnt that make too much wieght in the rear?
Old 10-27-2011 | 05:08 PM
MinnFlyer's Avatar
A mini. It's not that much weight
