Reload this Page >
***CUB BROTHERHOOD***
Old 11-30-2014, 07:46 PM
  #3001
acdii
Yeah, I tried a few times to reshrink while twisting, and it kept going back after a while and wrinkling the fabric. I think a touch or rudder trip will offset it enough to not be an issue. I also have a monster for an engine in it.
Old 12-07-2014, 12:49 PM
  #3002
acdii
Default Tail brace failure
On my SIG Cub, the tail brace uses Clevises, and they are too hard to drill and they have also snapped when trying to bend. I need something else to use, but dont know what. Is there a tail brace hardware pack out there? This is the last item I have left to complete before final balancing, everything else except the dummy engine is done. I even put in a pilots seat(though misplaced the instrument panel decal). It's not true to scale, but it looks good, and the one full body pilot I have fits it perfectly(looks like a kid with a fake mustache pretending to be a pilot). It secures the battery and charging jack/switch.
Old 12-07-2014, 01:17 PM
  #3003
spaceworm
My Sig 1/4 Cub uses 2-56 spring steel clevisis with one leg cut off. Perhaps another brad will not be as hard and can be bent and drilled out to a bigger hole for attaching to the stabs. Good luck.
Sincerely, Richard
Cub Brotherhood #187; Sig 1/4, H9 100 inch (Gen 1), GB Anniv Cub
Club Saito #635; Saito 56, 100, 120abc, 130T, 180
Kadet Brotherhood #96; Mk 1/II Kadet, Kadet Junior,
Sig Kougar, Sig 1/4 Cub, Sig 1/4 Spacewalker II
Old 12-07-2014, 01:44 PM
  #3004
acerc
acerc's Avatar
A picture is worth a thousand words so here is one from the Sig gallery.
Old 12-07-2014, 02:52 PM
  #3005
TonyBuilder
TonyBuilder's Avatar
Robert, that is one good looking cub, very nice.
TB
Old 12-07-2014, 03:01 PM
  #3006
acerc
acerc's Avatar
It's not mine, another cub brother owns it.
Old 12-07-2014, 08:06 PM
  #3007
acdii
I picked up a Sullivan tail brace kit that uses cables. It wasn't cheap so it better work.
In other news
Old 12-07-2014, 08:44 PM
  #3008
Super08
Super08's Avatar
The Sullivan brace kit works very well. I have used it on a couple planes with excellent results including a 82" span Super Sportster. To add strength as there was no plywood inserts, I glued short lengths of aluminum tubing into the stab and fin to prevent the balsa from crushing or tearing. It held up real well.
ID:	2053101   Click image for larger version
Old 12-08-2014, 06:57 AM
  #3009
acdii
Went through my checklist. All I have left are the tail braces, and check the balance once I finish installing the seat with the battery and switch installed. One thing not explained on the plans or the manual is the rubber banding on the landing gear, so not a clue how to connect that together. I was looking at the side profile and it needs something on that white expanse of canvas behind the cockpit, so went looking for 1 1/2" letters and they didn't have any at the LHS. Thinking of adding an N with my AMA number to the sides. I also misplaced the instrument panel, so will have to put that in whenever I locate it. I also have the decals that came with the kit somewhere, so have to find those too and add the little cub to the tail.
Old 12-08-2014, 11:40 AM
  #3010
cubcrasher
acdii
Check my post on the sig brotherhood.
Old 12-09-2014, 07:24 PM
  #3011
Cub Man
My Feedback: (50)
Cub Man's Avatar
For scale tail bracing take a look at http://thecubden.org/tail-brace-102
Old 12-10-2014, 06:44 AM
  #3012
acdii
Cub is done. That tail brace kit worked well, and looks pretty good too.
If weather holds up like forecast for Sunday and the winds are calm, I may maiden it. All depends on if I get it balanced and tuned by then. Should balance right on the money, but you never know until its done. The Saito should purr like it did before, but I had to remove the needle to get the cowl on.
ID:	2053602   Click image for larger version
Old 12-10-2014, 12:20 PM
  #3013
Leroy Gardner
Tail brace wires I put on a 1/4 scale Spacewalker, made the attachments from aluminum and put an eye-let in them for wear protection, and used a clevis on one end for adjustment with a piece of heat shrink slid over it. For scale I like cub mans illustration and plan to do that on my 1/4 scale Super Cub.
Leroy
ID:	2053697   Click image for larger version
ID:	2053698   Click image for larger version
ID:	2053699   Click image for larger version
ID:	2053700   Click image for larger version
Old 12-10-2014, 01:59 PM
  #3014
Corsair2013
Corsair2013's Avatar
Leroy, On the tail brace wires - are the actually functional or just for looks?
Does it matter if 1/3, 1/4, 1/5 scale or does it apply to all with tail brace wires??
Keith
Old 12-10-2014, 03:16 PM
  #3015
Leroy Gardner
Keith
Kieth the wires and braces do function in the overall support of the tail surfaces and help prevent flutter especially the larger surfaces. Notice the wires are all around most typically on the trailing edges and some add the leading edge support also. When the real planes we model have them it's because it's part of the design and very functional.
Leroy
Old 12-10-2014, 04:10 PM
  #3016
WacoNut
WacoNut's Avatar
On my 1/3 Cub they are functional. All Cub models would probably benefit from having functional wires added to them.
Charles,
How is your 1/3 Super Cub plans coming? I would really like to build one of them one of these days.
Later!!
Anthony
Old 12-10-2014, 05:43 PM
  #3017
acdii
As with the wing struts, the tail braces on the 1/5th are structural too. Really stiffens up the tail. Now that I have a nice spool of stainless cable and another kevlar one, the rest is easy to make for more bracing as I need it. Would be nice if I could find bulk threaded fittings that slip over the cables.
Old 12-11-2014, 07:35 PM
  #3018
Cub Man
My Feedback: (50)
Cub Man's Avatar
The super cub plans are coming along slowly. I have a couple areas that I have stepped away from to ponder over on how to best do and for building on it to keep it scale.
Big brown dropped a box at my door today. Wish it was a new plane...... But it's the shirts. I had to drop back one on teh shirts, but they are still great quality. Did this so we could have them before Christmas!!!!!. If nothing happens I will get them in the mail this Friday. I did buy a couple extra so if you want one go to the store on the cub den and order one.
Old 12-12-2014, 09:11 AM
  #3019
cubcrasher
Mail mine first.
Old 12-12-2014, 10:02 AM
  #3020
Cub Man
My Feedback: (50)
Cub Man's Avatar
They are all packed and ready to be dropped at the post office
Old 12-12-2014, 10:46 AM
  #3021
acdii
Can't really see it in this picture, but I added a step behind the landing gear fairing.
Old 12-13-2014, 08:54 AM
  #3022
Cub Man
My Feedback: (50)
Cub Man's Avatar
Ok guys. I need some help. As the say more then one set of eyes is best. Just moved the cub den to a new server. Let me know if you find any issues. Should be a little faster.
Old 12-13-2014, 10:06 AM
  #3023
spaceworm
Works great to me. Thanks.
Merry Christmas to All and to All a Good Flight.
Sincerely, Richard
Old 12-13-2014, 10:07 PM
  #3024
Cub Flyer Fresno
Cub Flyer Fresno's Avatar
Gee that is a nice one Ace. Where'd you find that one?
Old 12-14-2014, 01:34 PM
  #3025
acdii
Well I said before I was done, but I really wasn't, but I am now. I put the decals on, found the instrument panel, put that in, and finished the cow.
Ran up the engine yesterday, everything checks out, but too foggy today to maiden it. Really like how it came out. I may have a graphic made for the wing N number. The tail is my AMA number. The top wing I want the number to be black and white so that is stands out on the colors.
