Reload this Page >
***CUB BROTHERHOOD***
Old 10-20-2015, 04:53 AM
  #3701
FlyerInOKC
FlyerInOKC's Avatar
Give CubMan a bit he'll get you a number Pete!
Old 11-01-2015, 05:29 PM
  #3702
SunDevilPilot
SunDevilPilot's Avatar
Happy Halloween! (Full scale Cub fun)
http://youtu.be/6MWa_pGJwt4
Old 11-02-2015, 07:08 AM
  #3703
FlyerInOKC
FlyerInOKC's Avatar
Love it!
Old 11-13-2015, 12:53 PM
  #3704
p3arljam
Hello hopefully my initiation and hazing won't be to bad into the brotherhood if accepted. A very generous club member basically gave me this kit built 90"span with servos. This is his smallest plane and needed to make space for his 128" span Decathlon and 100" plus Bud Nosen P 51. I have a question I have a Saito 100 I will be using and i am debating on how to install the engine and looking for opinions. I can mount it sideways and the muffler will stick way out to the left or inverted and it will be at the bottom right or my preference some where between sideways and inverted with the muffler exiting the bottom. Let me know what you guys think. Also i hope i dont get banned for saying this but i would really like to do the military version of the cub what do you guys think? I am not sure how easy i can get the N numbers and lighting bolt off the covering is super coverite i have never dealt with this covering before . Any thoughts to leave it as is or should i go for it?
ID:	2130426   Click image for larger version
ID:	2130427   Click image for larger version
ID:	2130428   Click image for larger version
ID:	2130429   Click image for larger version
Old 11-13-2015, 01:23 PM
  #3705
RagwingFan
My Feedback: (31)
My two bits
I would mount sideways. Would be nice to have a curved exhaust elbow like the OS 4 strokes to help tuck muffler inward. I have had a couple inverted 4 strokes and have had issues with reliable running. I know it is done and others successful. Just did not work for me. I am thinking that 100 will be more than enough power for her. No issues here on military scheme. Cubs played an important role, of course most in the L-4 greenhouse configuration. Scheme is your preference. That is what's great about this hobby.
Good luck. I have several cubs, sizes, kit manufacturers etc. Can't beat them.
Old 11-13-2015, 01:38 PM
  #3706
FlyerInOKC
FlyerInOKC's Avatar
You might see if you can get a 90 degree adapter to fit this engine. I found one to fit my old FA-80 for an inline Saito. It allowed me to use the stock pipe and have the muffler exit out the bottom with the engine mounted inverted. That said I do have a curved pipe. Mine Cub has CAP decals and N number.
ID:	2130434   Click image for larger version
Name:	Cub Muffler.JPG
Old 11-13-2015, 01:42 PM
  #3707
FlyerInOKC
FlyerInOKC's Avatar
Anyone have any recommendations on how to choose elastic cord to use as a bungie for 1/5th scale Robart gear? I want to dump the O-Ring setup and thought I could pick up some at a fabric store like JoAnn's or Hancock.
Old 11-13-2015, 02:43 PM
  #3708
pilotbum
pilotbum's Avatar
Go to the drug store and buy the elastic hair bands girls use in their hair. They're cheap and they're basically a tiny bungee. It takes several of them to do the job but you can add/remove to your liking to achieve the desired stiffness in the gear.
Old 11-13-2015, 05:26 PM
  #3709
52larry52
p3arljam, I would let convince and ease of engine and muffler fitment be my guide for determining engine mount position, I am also generally not a fan of inverted engines, however I have a Saito 120 mounted inverted in a Rascal 110 and it starts and runs flawlessly even without adding an on board glow system. The only minor hitch is the need to have a "dummy" glo plug in the engine for storage and then changing to the "good run" glo plug as part of the at the field assembly before take off. The storage dummy plug will collect oil and be fouled being right at the lowest point and not what you want for the plug you will fly with. If you decide to mount the engine @ 90 degrees with the Saito head sticking out the right cowl side then you will need just one fax engine for the left cowl side. Either way is just fine. BTY, I am quite sure the Cub you have is a kit built Great Planes J-3 Cub 60 size. I have the 40 size ARF and they are good flyers. As to the military version may I suggest the U.S. Navy NE-1/NE-2 scheme as it retains all the Cub yellow covering with the addition of very early WWII U.S. rondals and "US Navy" in small letters near the rear of the fuselage. I have a 1/5 th scale (83") World models Cub done in this way and it sets it apart from the more common olive drab with invasion stripes look. No need to worry about not having the glass house version as some of the real military versions used in training were the stock windowed type. If you are in need of a cowl get one of the fiberglass replacements from someone like Fiberglass Specialties. Have fun, you will enjoy flying this bird.
Old 11-13-2015, 06:41 PM
  #3710
p3arljam
I currently have a 70" Decathlon with an inverted Saito 72 with a 90° adapter with no issues starting or performance. I have an inverted O.S. 91 FX on a 80" Super Sportster which I have to clamp the carb line while I fuel and after the first flight I know longer have to do it. I do have an extra cowl from fiberglass specialties as well and the original is s split cowl for a O.S. twin which my friend kept. If I can find a 90°adapter for this engine I will do the same if not I will mount it sideways and try and find a way to reroute the muffler. Hopefully there will be an easy way to remove the N numbers and lighting bolt.
Old 11-14-2015, 03:45 AM
  #3711
SrTelemaster150
SrTelemaster150's Avatar
Mount it inverted with the Saito 90* adapter & the exhaust can exit at the bottom center of the cowl.
Old 11-14-2015, 03:55 AM
  #3712
SrTelemaster150
HERE YOU GO!
Old 11-14-2015, 05:03 AM
  #3713
smkrcflyer
smkrcflyer's Avatar
I have the Great Planes cub with a Saito 72. Its mounted sideways with the cylinder at 9:00 and the exhaust exits in a good location. This also makes for easy access to the glow plug. Engine runs great never had a problem with it.
Old 11-14-2015, 08:10 AM
  #3714
acdii
I know this plane, my friend has one. He flies it with an OS 70 on it and he recently rebuilt it after an incident with a slap happy tree that ripped it apart. We played around with the engine position, and basically found that if the engine is mounted inverted without dropping the tank it has a good chance of flooding with a full tank. The FA100 is a much larger engine, and its spray bar sits lower than the OS when inverted, I know, I wanted to invert it in my SIG cub, but it would require dropping the tank floor which was not worth it. With the 100, mount it on the right, with the exhaust pointing down, also put a piece of fuel line on the crank breather and run it out the side by the exhaust, or make a scavenge tube, or you will be cleaning a lot of slime off the belly. If you can find one, use an Evolution 15x6 on it, flies it very scale like at half throttle, with some ooomph at WOT when you feel frisky. Mine is on a 1/5th SIG Cub, and its first flight was with a 14x6, went vertical on take off after about 10 feet, Way too fast a prop for the Cub. A 14x8 MAS gave good performance, but again, too much speed for the Cub. The big difference between the GP and SIG, your has a solid one piece wing that does not require the struts, where the SIG struts are 100% functional. It also has a slightly longer wing, not true scale like the SIG. It will fly real nice with that 100 on the nose.
ID:	2130571   Click image for larger version
Old 11-14-2015, 08:15 AM
  #3715
acdii
I just happened to have a photo of when I mounted it inverted. The tank CL is in the middle of the motor mount, and you can see that the middle of the carb is well below it.
The hole you see on the side of the mount is for the throttle cable when mounted sideways with the throttle arm on the bottom, tank CL is just a few MM below it.
Here is what I mean by a scavenge system. Its on my FG-11 to help pull the goo from the crankcase and keep the inside of the cowl clean.
Old 11-14-2015, 07:02 PM
  #3716
52larry52
p3arljam, As to removing the lightning bolt and N numbers, they went on with heat so they will come off with heat. Use your covering iron to warm up an end corner area of each item to be removed, pick at the corner with your hobby knife till you get it up and starting to come off, continue to heat the area at the edge as you peal each item off and clean up after with some alcohol. Finding just the right amount of heat to do this is the trick, start low and work the heat up until it starts to work. It's easy.
Old 11-15-2015, 08:37 PM
  #3717
Cub Man
My Feedback: (50)
Cub Man's Avatar
#1 Cub Man - Charles Brooks
#2 Minn Flyer - Mike B.
#3 acerc - Robert R
#4 Arup -
#5 Frequent Flyer -
#6 bikerbc -
#7 GAP RCU -
#8 rafeeki -
#9 Scirocco 14 - Mark
#10 Lins - Lindsey G
#11 CK1 – Chris
#12 Jaybird –
#13 heritageman -
#14 Live Wire - Larry K
#15 Saito18 –
#16 davidgeorge212 –
#17 WacoNut –Anthony
#18 raydar –
#19 no1isnormal –
#20 JH313 –
#21 JNorton – John
#22 FJRrider –
#23 lovetoflyguy – PJ
#24 Edwin – Edwin
#25 Lavell – Lavell
#26 crash bandicoute
#27 do335a –
#28 fred985
#29 Pa-18cub150 –
#30 cessna579 –
#31 cubcrasher –
#32 mac1va –
#33 morganflyboy –
#34 Steve Landron –
#35 mintie –
#36 Gordie M –
#37 extra-nut –
#38 snowball –
#39 eastkurt - Kurt
#40 JerryM –
#41 rcavi8or –
#42 meanrc –
#43 Rc Overkill –
#44 oldiron410 –
#45 Hill202 –
#46 weathervane – Andrew
#47 SunDevilPilot –
#48 iflyj3 – Dan
#49 gluemaster –
#50 EddieC –
#51 CanDo – Les
#52 dabigboy – Matt
#53 [email protected]
#54 woodworm –
#55 skipb
#56 mrdhub – Dan
#57 Homer712
#58 scaleman57 –
#60 psheffield
#61 quiltsfly
#62 G.Barber
#63 bobbailey
#64 scflyboy
#65 Cub Flyer Fresno
#66 FILE IFR - Mike T
#67 talob – Mike
#68 Lowvoltage – Joe
#70 Glyder – Chuck
#71 smkrclfyer –
#72 jeffEE
#73 GW –
#74 lever02
#75 AB Bob – Bob
#76 rede2fly –
#77 Barn-E-Stormer
#78 Ray S. –Ray
#79 Daniel-EL
#80 ExcaliburIII – Richard Longfellow
#81 jrb1 -
#82 on_your_six –
#83 BGCombs
#84 RevGQ
#85 jkr_1100
#86 Dope Fiend
#87 paero-RCU
#88 .50cal
#89 mrshea - Phil
#90 Cougar-RCU
#91 glenladen
#92 cublover
#93 lowbubba
#94 steve
#95 Gray Beard
#96 roaddog2
#97 biam
#98 rcpilotaviator
#99 funtana1
#100 rcavi8or
#101 GPutt33
#102 actionjackson
#103 sj3cub
#104 dreamwever
#105 phatbob02
#106 igoren
#107 N1EDM
#108 mrwad – Don
#109 dirtrod – Ty
#110 HawkI
#111 redkav
#112 GerKonig _Gerry
#113 SCOTT42
#114 5blue
#115 crazystick
#116 3[SUP]rd [/SUP]time Richard
#117 chevyman962000
#118 Mrj3cub
#119 Oldflyer2
#120 rogergh
#121 TEAMERICA
#122 cannonball200
#123 TripleDeucer
#124 tenspeed59 – Mark
#125 rcjunky67 – Robert
#126 VincentJ
#127 nalby
#128 fcf
#129 malitape
#130 sirzepp
#131 rmpRmP
#132 Rv7garage
#133 pt19 flyer
#134 JohnFH
#135 ahgoodman
#136 skyraider71
#137 Planejaw
#138 rc airplane nut
#139 Stan7476
#140 RDJeff
#141 rmpRmP
#142 oldfartpilot
#143 Big Lacy
#144 mnemennth
#145 Unclebuck21228
#146 WacoOne
#147 AV8RJIM
#148 retcaptafd
#149 dadragon
#150 boss_rc
#151 [email protected]
#152 msu68stang
#153 cowboy1969
#154 cubflyman
#155 akcub
#156 oldfartpilot
#157 jwrich
#158 rmyret
#159 tom_sandiego
#160 5skyhawk172
#161 archie05
#162 JerryM
#163 elaguilacalva
#164 arfwrecker
#165 I_Fly
#166 althepal88
#167 ROCKY1405
#168 scale buff
#169 Grumpy Monkey
#170 pt19 flyer
#171 Cloud Cruiser
#172 rye
#173 Props4ever
#174 oldfartpilot
#175 rcfighterjock
#176 cubkadet
#177 wildbills21
#178 RCJones
#179 FlyerInOKC
#180 WB6JGD
#181 Joey B
#182 cwhitacre21
#183 Yank II
#184 RCJones
#185 facia
#186 Aiden88
#187 spaceworm
#188 Sgt. Meyer
#189 LarsL
#190 jmcowart
#191 308jockey
#192 yak86
#193 p510851
#194 Bauer66
#195 baldguy
#196 acdii
#197 Mr-Punk
#198 skylark-flier
#199 braddock VC
#200 ThunderBoat42
#201 Ultimateflying
#202 FlyerInOKC
#203 John_M_
#204 Mako17
#205 bpoates25
#206 3136
#207 Loopdeeloop
#208 Jim Hargett
#209 deanz406
#210 darren4
#211 Murphey
#212 Horsepoweraviation
#213 Chucks
#214 Bob Howard
#215 Firewalkerd1
#216 Antares100
#217 motor12
#218 hogflyer
#219 bigbird3
#220 PeterC
#221 bwoofter
#222 Bush Flyer
#223 kevinf2501
#224 Jim Hargett
#225 shiprex
#226 Super08
#227 randomvector
#228 jvance
#229 Fly North
#230 Corsair2013
#231 SrTelemaster150
#232 larscato
#233 TheComputerGeek
#234 iflyfloats
#235 cubcrafter60
#236 Leroy Gardner
#237 d boothe
#238 TonyBuilder
#239 ALLSCALE1
#240 stankinator
#241 thebighawg
#242 rickj
#243 Clavin01
#244 Eddym
#245 Quigleywins
#246 newbiedc
#247 Skinny Bob
#248 bobbailey
#249 newbiedc
#250 acdii
#251 mustangherb
#252 52larry52
#253 FlyWheel
#254 ArcadeAir
#255 pilotbum
#256 jimbrock2
#257 sckevan
#258 wistillwill
#259 panhandler
#260 BUDMAN27
#261 Billy J
#262 dj9124
#263 RagwingFan
#264 BrightGarden
#265 p3arljam
Old 11-16-2015, 06:14 AM
  #3718
FlyerInOKC
FlyerInOKC's Avatar
I'm with you I like a scavenge system too to help keep the aircraft cleaner! I was shown how to make this system by an old local club member. He flew scale ARFs but added this to everyone of his airplanes. A drill bit is used to form the strap to hold the brass tube and the muffler itself to form the clamp. I prefer using fuel line for most of the distance but your brass tube design would work as well.
Old 11-16-2015, 05:46 PM
  #3719
acdii
Whats surprising is the muffler doesn't melt the zip tie. I used soft brass 1/8" tubing to this. I like how you did yours, looks cleaner.
Old 11-17-2015, 05:52 AM
  #3720
FlyerInOKC
FlyerInOKC's Avatar
Thanks! It's easy enough to build, next time I'll extend the outlet into the exhaust stream a bit more. Fred realy did me a good turn telling me how to make them. He is a good egg and always willing to help another flier. I have seen him in a couple years he may have passed.
Old 11-17-2015, 10:05 AM
  #3721
Lennyshotgun
[h=2]1/4 scale Sig Cub convert to electric[/h]
Has anyone out there converted a Sig 1/4 scale that can give me some advise. Where to place battery, hatch? did it need nose weight, issues you may have run into, setup, prop size. I plan to put it on floats eventually, do I need more motor?
If not a "Sig" any 1/4 scale cub.
Thanks in advance.
Lenny
Old 11-17-2015, 10:45 AM
  #3722
acdii
Thanks in advance.
Lenny
You could probably fly it very well with an E-flite 110 brushless and an 18x6 prop. The battery would go in the area of the fuel tank. You can make a battery tray that slides out, or several of them for spare packs, and use a screw to secure the tray to a mount you add once you get the balance where you need it to be. To get an idea of the battery tray, look up the SIG Something Extra ARF manual, they come with one. A power 90 would also work. They are equal to a 2 stroke, 110 or 90, and the SIG recommends a 90 2 stroke for power. If you are floating it, go for the 110.
Old 11-17-2015, 01:22 PM
  #3723
Lennyshotgun
Thanks for the comeback.
I have a Tacon 160/245 kv motor that I thought I could use on 10 cells, prob more then I need but I can always throttle back
My main concern is balance. I've done many conversions to electric, and always need to add nose weight, is this true with the Cub. The servos in the fuse are moved to the front (I got the Cub from a friend getting out of the hobby) If I need nose weight I would rather go with bigger batteries, or that 160 motor, if nose weight is not needed I will prob buy a 110.
Whatdaya think?
Old 11-17-2015, 01:24 PM
  #3724
Lennyshotgun
Whatdaya think?
Old 11-17-2015, 05:01 PM
  #3725
52larry52
Lenny, Don't forget to install a "sound system" that makes good Cub like engine noise.
