Reload this Page >
LT40 Clipped Wing Starburst Covering
Old 12-30-2011, 04:25 PM
SeamusG
SeamusG's Avatar
Default LT40 Clipped Wing Starburst Covering
Ijust finished the 3rd covering of my LT-40. I've included the "goal"pics and the finished result. I also took some 225 pics along the way. If there is interest I'm willing to do an "after the fact" covering thread of a trainer. Let me know.
Materials included Ultracote Bright Yellow, Black and Chrome.
ID:	1707174   Click image for larger version
ID:	1707175   Click image for larger version
ID:	1707176   Click image for larger version
ID:	1707177   Click image for larger version
ID:	1707178   Click image for larger version
ID:	1707179   Click image for larger version
ID:	1707180   Click image for larger version
Old 12-30-2011, 05:38 PM
Thatsakitbuilt
Default RE: LT40 Clipped Wing Starburst Covering
Hey SeamusG,
The LT looks really sharp. How much did you clip. And have you flown it yet? If so, how did she fly? I've got one in the hangar, and one NIB on the shelf. I may want to clip mine.
Cal
Old 12-30-2011, 06:27 PM
SeamusG
SeamusG's Avatar
Cal - I simply cut one rib off and the tip of course. It now has a flat tip rather than the upward angled tip.
No flight time - just finished covering this morning and currently setting up the throws. The high speed needle decided to run away. Emmmm, that just ain't nice. [8D]
Btw - initial build was box stock with rubber bands and tri-cycle gear. 2nd iteration resulted in wing mounted with bolts (a bayonet mount similar to the Kadet Senior ARF) and tail dragger. Took nearly 16 oz. of weight up front. After an aggressive nose over I decided to go back to a tri-cycle gear to lighten things up and clip a wing. In first two forms staight-n-level was at 1/2 throttle - anything above that resulted in an aggressive up line. We have a frozen finger fun fly Jan 1 - just maybe ....
Old 12-30-2011, 06:39 PM
fly20
Would love to see a how to. This might just be the finish I use on my telemaster 40. thanks
Old 12-30-2011, 08:09 PM
rafeeki
rafeeki's Avatar
Nice job SeamusG,
Did u start off by covering it all with yellow then applied the black? If so how did u manage to get such a perfect looking covering? No air bubbles?
Old 12-30-2011, 08:23 PM
SeamusG
SeamusG's Avatar
The entire plane was first covered in yellow. Definitely my best work to date. Oops - except for the forward part of the fuse & cowl.
Then came the black trim. Before I started my trim I had conversations with MinnFlyer as he was doing a similar scheme on his Cub (cub yellow and black). He used Xylene as an Ultracote adhesive activator for all trim but the wings. For the wings he traced the wing trim's outline onto the yellow base and then cut the yellow from inside the trim outline leaving 1/2" boarders. I used the old standby of applying the trim with an iron. Only problem, my favorite trim iron's foot broke just before I started laying out the black. I used my standard iron for the first time in this role. I totally screwed up the trim work. Most would say that it's pretty good but I'm accustomed to having a rare bubble in my trim. It looks fine at 5 feet. It will look great in the air.
ID:	1707274   Click image for larger version
Old 12-30-2011, 08:26 PM
rafeeki
rafeeki's Avatar
Would spraying Windex activate the adhesive before applying the trim?
Old 12-30-2011, 08:46 PM
SeamusG
SeamusG's Avatar
ORIGINAL: rafeeki
Rafeeki - that method is exclusively for use with Monokote. Ultracote's adhesive is different and is not affected by the ammonia in Windex. Now, if Windex starts using Xylene, then it just might work.
Old 12-30-2011, 08:48 PM
rafeeki
rafeeki's Avatar
Not familiar with Xylene, is it a paint remover?
Old 12-30-2011, 08:50 PM
SeamusG
SeamusG's Avatar
ORIGINAL: fly20
The biggest "time"challenge that I had was getting a good balance in the size of the starbursts. There's a thread specific to starbursts - it really peaked my interest. I downloaded some samples from "out there". Ichose to use the format of the ARFpieces pictured. The yellow and black is MinnFlyer's beautiful work.
I have a 2D engineering oriented tool (Microsoft's Visio). I copied the images into Visio and made outlines. These were then overlayed on top of my yellow LT40 image. Lines were drawn and the starbursts were changed to black. Note that the proportions of the Cub and LTwings differ considerably. I still used the same proportions on the LT.
Idid like the idea of having the "convergence point" of the starbursts nearly on the foremost part of the leading edge. Gives are very nice swept back look. I had started by using an approach similar to MinnFlyer's of having a constant width of yellow in front of the first "burst"on the wing, fin and stab. It just looked more active with the point up forward.
ID:	1707286   Click image for larger version
ID:	1707287   Click image for larger version
ID:	1707288   Click image for larger version
ID:	1707289   Click image for larger version
Old 12-30-2011, 09:06 PM
SeamusG
SeamusG's Avatar
ORIGINAL: rafeeki
It is a solvent that uses Xylol - Xylene is a brand name and sold at ACEhardware. MinnFlyer loaded up an old CA "kicker"spray bottle with Xylene to spray the area. Nice idea. However, the plastic bottle was seriously softened by the next morning. Xylol is not for the faint of heart.
Old 12-30-2011, 09:11 PM
SeamusG
SeamusG's Avatar
Just a thought - I am seriously considering adding a piece of clear Ultracote over all of the convergence points to keep the tips from peeling up during flight / fuel residue.
Old 12-30-2011, 09:34 PM
SeamusG
SeamusG's Avatar
Iapproach covering somewhat like painting a room. First thing is to plan. Next "cut-in" the room so that painting the field will be easy. Then paint the base. Finally, apply any special trim.
Here's pics of the "cut-in"process 1 of 2.
ID:	1707307   Click image for larger version
ID:	1707308   Click image for larger version
ID:	1707309   Click image for larger version
ID:	1707310   Click image for larger version
ID:	1707311   Click image for larger version
ID:	1707312   Click image for larger version
ID:	1707313   Click image for larger version
ID:	1707315   Click image for larger version
Old 12-30-2011, 09:35 PM
SeamusG
SeamusG's Avatar
Cut-in 2 of 2 ...
My goal is to make sure that all inside corners are well sealed from glow goo and that there is full color coverage in the seams.
I add a strip along the fixed hinge line so that I can cut the covering for the hinge slots ANDdrill 1/16" vent holes into the interior air spaces so that the heated air from shrinking the covering has a place to go rather than ballooning the covering.
ID:	1707318   Click image for larger version
ID:	1707319   Click image for larger version
ID:	1707320   Click image for larger version
ID:	1707321   Click image for larger version
ID:	1707322   Click image for larger version
ID:	1707323   Click image for larger version
ID:	1707324   Click image for larger version
ID:	1707326   Click image for larger version
ID:	1707327   Click image for larger version
Old 12-30-2011, 09:39 PM
SeamusG
SeamusG's Avatar
Time for covering the fuse "field"
ID:	1707331   Click image for larger version
ID:	1707332   Click image for larger version
ID:	1707333   Click image for larger version
ID:	1707334   Click image for larger version
ID:	1707335   Click image for larger version
ID:	1707336   Click image for larger version
ID:	1707337   Click image for larger version
ID:	1707339   Click image for larger version
ID:	1707340   Click image for larger version
ID:	1707341   Click image for larger version
Old 12-30-2011, 09:42 PM
SeamusG
SeamusG's Avatar
More field covering on the tail ...
Oh yea - that balsa block has smooth leather applied to one side and 2000 grit paper on the other side. I use it the keep the razor blade & X-acto #11 blades sharp. I used 1 razor blade and 1 X-acto #11 blade to cover the entire plane. Not as good as Gray Beard but I'm pedaling as fast as I can.
ID:	1707343   Click image for larger version
ID:	1707344   Click image for larger version
ID:	1707345   Click image for larger version
ID:	1707346   Click image for larger version
ID:	1707347   Click image for larger version
ID:	1707348   Click image for larger version
ID:	1707349   Click image for larger version
Old 12-30-2011, 09:43 PM
SeamusG
SeamusG's Avatar
The last of the base covering of the tail.
ID:	1707352   Click image for larger version
ID:	1707353   Click image for larger version
ID:	1707354   Click image for larger version
ID:	1707355   Click image for larger version
ID:	1707356   Click image for larger version
ID:	1707357   Click image for larger version
ID:	1707358   Click image for larger version
Old 12-30-2011, 09:47 PM
SeamusG
SeamusG's Avatar
On to covering the fuse bottom ...
ID:	1707363   Click image for larger version
ID:	1707364   Click image for larger version
ID:	1707365   Click image for larger version
ID:	1707366   Click image for larger version
ID:	1707367   Click image for larger version
ID:	1707368   Click image for larger version
ID:	1707369   Click image for larger version
Old 12-30-2011, 09:48 PM
SeamusG
SeamusG's Avatar
Then the sides - 1 piece of yellow ...
ID:	1707372   Click image for larger version
ID:	1707373   Click image for larger version
ID:	1707374   Click image for larger version
ID:	1707375   Click image for larger version
ID:	1707376   Click image for larger version
ID:	1707377   Click image for larger version
ID:	1707378   Click image for larger version
ID:	1707380   Click image for larger version
ID:	1707381   Click image for larger version
ID:	1707382   Click image for larger version
Old 12-30-2011, 09:51 PM
SeamusG
SeamusG's Avatar
Finished off one side ...
ID:	1707384   Click image for larger version
ID:	1707385   Click image for larger version
ID:	1707386   Click image for larger version
ID:	1707387   Click image for larger version
ID:	1707388   Click image for larger version
ID:	1707389   Click image for larger version
ID:	1707390   Click image for larger version
ID:	1707392   Click image for larger version
ID:	1707393   Click image for larger version
ID:	1707394   Click image for larger version
Old 12-30-2011, 09:52 PM
SeamusG
SeamusG's Avatar
On to the fuse top ...
OK - what happened to the fin? Well, the plane toppled off the table. I noticed that the fin base covering was wrinkled. Thought it was broken. Pulled off the covering. Nope, nothing broken BUTyou could move the fin back-n-forth. ????? I added support blocks at the fin's base and added a CF hollow rod vertically to provide support.
Didn't work as planned - stiffer but the first hanger hit or student mess up and that fin would break off. The stab covering was removed. Still no smoking gun. The fin didn't seem cracked anywhere. The 30-min epoxy was holding nicely. But it still flexed too much. I saturated the entire foot of the fin with thin CA. Em, rock solid - dead solid perfect. ???? Only thing that Ican think of is that the grain of balsa used for the footwas weak and that the CA covered that inherant weakness.
ID:	1707402   Click image for larger version
ID:	1707403   Click image for larger version
ID:	1707404   Click image for larger version
ID:	1707405   Click image for larger version
ID:	1707406   Click image for larger version
ID:	1707407   Click image for larger version
ID:	1707408   Click image for larger version
Old 12-30-2011, 09:59 PM
SeamusG
SeamusG's Avatar
If you look closely in the last pic you can see a seam about an 1" in front of the fin's LE.
ID:	1707411   Click image for larger version
ID:	1707412   Click image for larger version
ID:	1707413   Click image for larger version
ID:	1707414   Click image for larger version
ID:	1707415   Click image for larger version
ID:	1707416   Click image for larger version
ID:	1707417   Click image for larger version
Old 12-30-2011, 10:01 PM
SeamusG
SeamusG's Avatar
Blech - control surfaces.
I used 3 pieces for each surface - 2 tips and 1 sheet for both bottom and top.
ID:	1707420   Click image for larger version
ID:	1707421   Click image for larger version
ID:	1707422   Click image for larger version
ID:	1707423   Click image for larger version
ID:	1707424   Click image for larger version
ID:	1707425   Click image for larger version
ID:	1707426   Click image for larger version
Old 12-30-2011, 10:03 PM
SeamusG
SeamusG's Avatar
Finished up the control surfaces ...
ID:	1707428   Click image for larger version
ID:	1707429   Click image for larger version
ID:	1707430   Click image for larger version
ID:	1707431   Click image for larger version
ID:	1707432   Click image for larger version
ID:	1707433   Click image for larger version
ID:	1707434   Click image for larger version
Old 12-30-2011, 10:05 PM
SeamusG
SeamusG's Avatar
The wing - started by covering around the mount structures ...
A template was cut from craft paper in pic 1.
ID:	1707440   Click image for larger version
ID:	1707441   Click image for larger version
ID:	1707442   Click image for larger version
ID:	1707443   Click image for larger version
ID:	1707444   Click image for larger version
ID:	1707445   Click image for larger version
ID:	1707446   Click image for larger version
