 Goldberg Chipmunk plans >
Old 02-11-2012 | 12:11 AM
Default Goldberg Chipmunk plans
Hi guys.
I am starting to build this plane but it's an old kit and plans are in a very bad shape. Somebody's got a digital version of these plans?
Thank you.
Old 02-11-2012 | 07:15 AM
daveopam's Avatar
My Feedback: (9)
Default RE: Goldberg Chipmunk plans
Just a heads up. Some of the early kits from this plane had a mistake in the intructions/plans. It showed the ribs as being the same on top and bottom and they are not that way. Pleasee be carefull to get them all the same direction. I would dry stack them all and maybe make a mark on the top of them with a Sharpie.
david
Old 02-14-2012 | 01:08 PM
I have scanned my plans 1:1, i have them in PDF format I can email them to you if you still need them.
Dom
Old 02-14-2012 | 02:07 PM
ORIGINAL: Domdezzy
Dom
It would help me very much thank you. My email address is [email protected]
Old 02-22-2012 | 02:56 PM
I have a set of unused plans for the GP Goldberg Chipmunk that you are welcome to have. They are from a kit I just bought so they should be up to date.
Dave is correct there are some ribs that need to be orientated in the correct position. However if you are going to put the servos in the wing (recommended) and/or are not going to use flaps it really doesn't matter.
Good luck on your Chipmunk and if you are interested in the plans let me know.
rv9-a
Old 04-19-2013 | 10:32 AM
I could use those chipmunk plans if you still have them. [email protected] Thanks Mike
Old 04-19-2013 | 10:52 AM
I'm ticked off, I had the box on the floor under a work bench and my basement flooded yesterday, soaking the box and getting the plans and manual wet.  Hopefully they dry out, and since the plane is nearly built, only some hardware and scraps got wet, but the box is trashed now.
