Balsa USA 1/4 Scale Nieuport 28 Build
If I were without the wife I could have stayed there all day! What a great display of aviation. The WWI and WWII sections were the most amazing. Each plane had its own pad complete with info and pictures.
The lighting was a little difficult for photos due to the darkness but if your camera can handle a little higher ISO and you have stabilization they can be taken.
I spent a bit of time with the Nieuport 28 and here are some of the photos. I have some additional photos of some of the linkage.
Building to resume shortly,
SunDevilPilot
Hey SDP, Once again you are doing a fantastic build thread. I feel like a groupie!!
Do you have any pics of your table saw setup? Is it a full table saw with a different blade or a smaller hobby sized table?
Lately I have been using my bandsaw quite a bit. I find it cuts almost as good as the table saw with a nice blade installed and the fence attached. It is also a lot safer to use. The blade of a band saw pulls the workpiece into the table. The table saw likes to try and fire it back at you. I have never lost my "Fear" of the table saw, which is a good thing I guess.
I'll throw in a photo of the table saw as well as an overview of my other tools. You'll note they are all on wheels. My wife and I park in the garage so I need to be able to shove the bigger tools into the edges.
SunDevilPilot
Here are some of the wood working tools from the original Boeing Factory. 12" table saw, planer, jointer, and a 36" bandsaw. I like the complete lack of safety devices on these. All belt fed from above.
SunDevilPilot
Any news on the rear stringers ?
SunDevilPilot
Sundevilpilot I have been silently lurking around your thread since you started it. I love antique aircraft and your subject has to be almost everybody’s favorite.<o></o>
The photos you posted of the museum brought back memories of my visit there 10 years ago where I was fortunate to view a beautiful golden oldie.<o></o>
It’s a Caproni Ca. 20 monowing in it’s original covering (the only one ever built). It is said that it was the worlds first fighter plane.
Try aiming that gun at a moving target.
I have since always wanted to try to replicate it in a ¼ scale model all the way to the now tatty antiquated covering.<o></o>
Notice the fully enclosed le Rhône engine with cooling inlets in the huge spinner. Very advanced streamlining for 1914.
Was this beauty still there?<o></o>
Sorry for the brief hijack <o></o>
<o></o>
mike<o></o>
<o></o>
mike<o></o>
It looked like it would fly!
SunDevilPilot
And I will need to fly these art pieces on a plane!
I heard Denis say it took about 70 hours to assemble and paint these. I am really thrilled he gave that time to me.
Thanks Denis !!!!
Phil
Today I begun the process of adding the stringers to the rear of the fuselage.
I have never done this process before so, as instructed by other builders of this model, I will follow Balsa USA's instructions to the letter.
So far I have installed three sets of fuselage formers, and still have two left (Each sets has four components). Easy enough but I am taking great care to get them straight to assist in keeping the stringers straight.
I should be able to get all the formers in place today and begin the process of adding the stingers tomorrow.
Some of the die cutting on the formers is a little rough, appear to have been double stamped, but I should be able to work through the issue.
SunDevilPilot
Today I started adding the stringers to the rear of the fuselage. I have never done this type of building before and so far it is going OK. Hopefully I am doing them correctly. The top and bottom stringers are nice and straight. The ones on the side taper inwards at the second to last rear former. The fuselage changes shape in that area, round into an oval, so hopefully this is correct. I have looked at the three view in the manual and the top down view appears to reflect this.
I can tell you now, working with stringers is a little tedious. Four installed and only a bunch more to go.
SunDevilPilot
I have been using the minumal amount of weight (Wood Blocks) to keep the stringers down in their notches until the glue sets up.
Seven to go.
SunDevilPilot
I went to the Airforce Museum in Dayton Oh today and they have a N28 on display so I snapped a few pics for you. The lighting is terrible in that place for taking pics. I tried to get some closeup pics of some of the details I thought you might find interesting.
If you want the full res images send me a PM and I will send them to you via e-mail.
Later!!
Anthony
Hi SDP,
Later!!
Anthony
I'm juggling the repair of my Cub and progress on the Nieuport. I need to order a tailwheel assembly for the Nieuport so I can add the gear plate to the rear of the fuselage. I plan on ordering that on Monday. I usually prefer the Sig leaf-spring setup. Simple gear and works great.
Work will continue!
SunDevilPilot
So.....
My poor Cub was sitting there all smashed. I had to keep moving it to get to my other planes. I just hated looking at it. Building was stopped on the Nieuport until I can get the Cub repaired.
The repair process is just about complete. Once I get the radio installation in the fusealge completed and the windshield reinstalled I should be able to start up the Nieuport build again.
The Nieuport will be built, just a little delayed.
SunDevilPilot
Phil
Trust me, when you get to covering get Solartex!!
No, I dont work for them.
SunDevilPilot
