 2 Part Fuselage >
2 Part Fuselage
2 Part Fuselage
Old 04-29-2012 | 06:00 PM
Default 2 Part Fuselage
Has there ever been a kit with a 2 part fuselage or has anyone seen one?
I have a car. No truck or van to carry my planes and I would like to have a plane that uses a 30cc to a 50cc engine but I need a max length in the 60" length or less. A fuselage with a rudder attached will not fit. So with the servos in the tail will be fairly easy to manage. I would prefer to use a known and tested way to disconnect the tail section if it exist.
I appreciate your input and time
Old 04-29-2012 | 06:27 PM
Default RE: 2 Part Fuselage
12 foot Telemaster.
Old 04-29-2012 | 06:49 PM
ByLoudDesign's Avatar
I have the Dee Howard 500 and the soon to be released Lockheed P-3 Orion!
Old 04-30-2012 | 03:05 PM
Hostetler had a pt-19 that had a removable stab and rudder.they bolted in place.you could consider a trailer or even roof racks
Old 05-01-2012 | 12:51 AM
Boomerang1's Avatar
The BVM 80 inch Sabre uses carbon rods which slide into sockets.
The rods are clamped by screws accessable from outside the fuselage.
http://www.bvmjets.com/pages/kits/f86_80.htm
Not sure if the hardware is available as an accessory.
If it is it will be high quality & cost a packet. - John.
Old 05-01-2012 | 05:47 PM
Boomerang1- that is a great example, I can get some options from the plans. I do not see that it as an option on the parts list. Bummer.<div>Thanks</div>
