Reload this Page >
Goldberg Tiger Club
Goldberg Tiger Club
Old 12-25-2016, 08:45 PM
  #1226
hairy46
Awesome!
Old 12-26-2016, 02:35 PM
  #1227
VCScott
VCScott's Avatar
Originally Posted by Gerd.von
At last! Today I finished to install the engine and fuel lines, ldg gear and canopy. Haven't tried the engine yet, hope it runs niceley!
Looks great , super clean, nice work!!
How is the cowling attached?
Scott
Old 12-26-2016, 06:54 PM
  #1228
rye
My Feedback: (10)
hi
i like to know what cowl did u use for your tiger ,thanks
Old 12-27-2016, 06:21 AM
  #1229
FlyerInOKC
FlyerInOKC's Avatar
Fantastic!
Old 12-28-2016, 10:19 AM
  #1230
winemaker
Sign me up.
I acquired an almost complete Tiger Twin. I am putting 2 Magnum 52 4 strokes in the plane. Has anyone know, made or flow such a bird.
Winemaker
Old 12-28-2016, 02:24 PM
  #1231
hairy46
No but I bet it flys like a tiger on steroids, you will have to post your first flight with it!
Old 12-28-2016, 03:47 PM
  #1232
spaceworm
Originally Posted by winemaker
Sign me up.
Winemaker
How about some pics? Build completion, covering, first flights? Thanks.
Old 12-28-2016, 05:26 PM
  #1233
Gerd.von
Hey! thanks for the comments. The cowling is custom made, I took many ideas from a few tiger build threads.
still haven`t tried the engine yet
ID:	2194760   Click image for larger version
ID:	2194761   Click image for larger version
ID:	2194762   Click image for larger version
ID:	2194763   Click image for larger version
ID:	2194764   Click image for larger version
Old 12-28-2016, 06:51 PM
  #1234
FlyerInOKC
FlyerInOKC's Avatar
Good looking wood cowling!
Old 12-29-2016, 04:51 PM
  #1235
VCScott
VCScott's Avatar
Thanks for the pics, Good work!
Old 12-29-2016, 06:17 PM
  #1236
Gerd.von
Today I tested my GGT-15. First attempt succesful!  It runs pretty smooth.
https://youtu.be/55tS2bA97gk
Old 01-25-2017, 06:49 PM
  #1237
Gerd.von
Well... Last Saturday I went to the field, started to work on the engine running-in, The ggt-15 gave us a bit of a hard time, we had to close the mixture control valve a few degrees, although the manual states to keep it as it is until the running in is complete, but it just kept choking, fuel was pouring from the carb all the time, I don't know if it was because the engine is mounted inverted, but it worked. I think we left the mixture control valve rich enough so it won't have any problems during and after the running in. The needle valve seems to be too sensitive 1 click less and it's too rich, 1 click more and it is too lean you got to find the exact position. Anyway after a half an hour we finally managed to tune it.
After 2 tanks I started to receive some pressure from the other guys to give it a try and fly it, so I gave in and I finally flew my Tiger.
It flew better than I expected. As soon as it took off It showed a tendency to roll left, I guess the ggt-15 is too big for the plane I'm guessing this was due to torque, after several clicks on the rudder and aileron trim, roll tendency was neutralized but after half a pattern I just couldn't make it fly straight and level, it had also a tendency to pitch down, a few clicks to the elevator trim and the problem was solved...
I received a lot of help from a friend to trim it, I was too nervous and worried trying to keep control of the plane, but once it was trimmed I calmed down and started enyoing the thing...
This was my first try with a tail dragger and sports plane, I was expecting a wilder plane but it turns out the tiger is smooth and easy to fly, had to try three times for landing cause no matter how soon I throttled to idle it kept coming too fast every time.
Second flight went smooth, I started doing more manouvers and really enyoied it. But I ripped the landing gear off during landing I kept flying more than I should have, so in my second attempt to land while I was going around the engine quitted and had to make an off field landing.
Dammage was minor, the landing gear came off with its respective chunk of plywood... A few hours of work and it will be ready to fly again... I'm happy...
Here's a video of its first flight...
https://youtu.be/jw95_Wh-NaA ————————
Goldberg Tiger Club #82
Gerd.Kenobi
Old 01-25-2017, 07:44 PM
  #1238
thailazer
thailazer's Avatar
Congrats on the flight! That is a lot of power for sure, but looks like you will get the handle on it soon. Nice video and looks like a great place to fly.
Old 01-25-2017, 08:29 PM
  #1239
hairy46
Great post thank you, enjoyed!
Old 01-25-2017, 08:41 PM
  #1240
Twin_Flyer
the Tiger looks awesome!!
Old 01-25-2017, 08:49 PM
  #1241
brockettman
brockettman's Avatar
Well done! Sorry to hear about the dead stick landing...
I have made some progress on my build over the last couple of years... I am installing retracts, so far so good!
ID:	2198218   Click image for larger version
Old 01-26-2017, 04:05 AM
  #1242
donnyman
donnyman's Avatar
Gerd.Kenobi
Hello!
I was looking at your video and it appears the fuel tank is to high in relation to the carburetor, and maybe the reason the fuel gravity feeds to the engine. May I suggest you try the engine upright to minimize this problem.
Happy flying..........donnyman
Old 01-26-2017, 08:09 AM
  #1243
FlyerInOKC
FlyerInOKC's Avatar
With the only damage being a torn out gear I would say it was a great flight! The Tiger is a great design and will bring you a lot of fun flying!
Old 01-26-2017, 02:15 PM
  #1244
Gerd.von
Thanks for all your comments!
That's a great looking build brockettman.
will work on that donnyman, thanks for the advice!
Old 01-29-2017, 06:22 PM
  #1245
thailazer
thailazer's Avatar
I bit on the Phoenix Models Tiger 3 and thought I would post some photos of this little copy cat! Quite well built overall, but the covering is hard to shrink and the hot glue used in some areas is poor. (The aileron servo mounts snapped off with light finger pressure. ) At a 109 bucks, it is cheap and fast way to get up in the air, but a well built Goldberg Tiger is still going to be a better airplane.
The dimensions of the Tiger 3 are almost identical to the Tiger 2 with the only real difference being the engine firewall is a bit further forward. Other than that, the planforms and dimensions are near identical.
Name:	Tiger 3 - 1 (1).jpg
ID:	2198863   Click image for larger version
Name:	Tiger 3 - 1 (2).jpg
ID:	2198864   Click image for larger version
Name:	Tiger 3 - 1.jpg
Old 01-29-2017, 11:14 PM
  #1246
Twin_Flyer
Nice, will have to add
one to my wish list at Tower and see if it goes on sale at some point.
Old 02-01-2017, 02:15 AM
  #1247
David Bathe
David Bathe's Avatar
David Patrick really knew his stuff, the Tiger was a marvellously flying sports model, had one decades ago. Many pattern pilots inc myself made some simple mods to the Tiger and used them for practice.
We extended the rear fuselage and positioned the stab/fin 3 inches further back. Made a new rudder 2x as wide. Dropped the engine thrust line 1 inch and shortened the wings by leaving out the last rib bay.
Make as a tail dragger, keep everything as light as possible. A wonderful Dave Patrick hybrid.
Old 05-30-2017, 03:09 AM
  #1248
lonestoner
Had my season opener yesterday and the tiger is such a good airplane, went out to Muncie with wind blowing everywhere flew at 1/2 throttle and had maybe 4 flights , all in all went great the tiger lives on !!
Old 06-07-2017, 10:06 AM
  #1249
NORTH2861
does any one have plands for a 120
Old 06-29-2017, 07:57 PM
  #1250
Leroy Gardner
I love the Tiger 60 I built sometime back. Just about everything on it was modified and it has a DLE 20 in it and I added flaps for aerobatics. It's a blast to fly and it will do anything you can give it and hover also. Wings are sheet'ed to support the covering job. Cowl is custom made fiberglass. Wings are mounted on an aluminum tube.
Leroy
ID:	2222329   Click image for larger version
