LOW TACK TAPE
LOW TACK TAPE
I'm going to build a model that calls for using Low tack tape during several steps. What is low tack tape? Masking tape? Scotch tape? Blue painting type tape? thanks in advance!
RE: LOW TACK TAPE
Drafting tape looks just like masking tape but is much less sticky. It costs about twice as much. You can get it at office supply stores.
Whether you really need something this low tack, or masking tape will do, is a different question. Drafting tape is useful for masking because it won't pull the underlying paint layer off. If you need to temporarily stick something to paper, drafting tape is good. But if all you need is something to keep from sanding too far (like putting tape on ribs when you sand a trailing edge to shape), masking tape works fine. Drafting tape in that kind of use would come off too easily and it would be an unnecessary expense.
My Feedback: (-1)
RE: LOW TACK TAPE
Not all the blue masking tape is low tack. I have both types in my shop and the regular blue masking tape will lift paint from a plane when you remove it. That's why I tried the low tack. The problem I had with it was it didn't stay stuck. It tended to lift on it's own. I checked last night and it does say low tack on the package.
My Feedback: (13)
RE: LOW TACK TAPE
there are several masking products there is a white version of low tack a blue version and a green type
the blue is what I use for sticking parts,or sheeting into place for positioning, usually the full tack version because on raw balsa the lighter version tends to become unstuck rather quickly, and actually costs more than the regular 3M blue stuff.
for those who may be painting there models and are looking for crisp lines I would recommend the 3M green tape its called clean edge because it resists bleeding along the lines and also releases from the surface you have masked off, it works allot better than the blue tape and gives a nice crisp line when pulled off the surface
RE: LOW TACK TAPE
I needthe tapeto hold the horizontall stab perpindicular to the vertical stab while the epoxy curesafter installingthe horizontal stab. The vert stab is already attached to the fuselage (ARF). I guess the idea is to have tape that won't damage the already covered horiz stab.
RE: LOW TACK TAPE
ORIGINAL: TPL33
I need the tape to hold the horizontall stab perpindicular to the vertical stab while the epoxy cures after installing the horizontal stab. The vert stab is already attached to the fuselage (ARF). I guess the idea is to have tape that won't damage the already covered horiz stab.
Banned
RE: LOW TACK TAPE
"For that purpose, I'd use ordinary masking tape. It won't damage a film covering "
Use caution. If it is an ARF, and the trim is painted on, it could lift the trim.
Les
Les
RE: LOW TACK TAPE
ORIGINAL: LesUyeda
''For that purpose, I'd use ordinary masking tape. It won't damage a film covering ''
Les
Les
