 How much dope will I need? >
Old 02-04-2013 | 07:01 PM
Default RE: How much dope will I need?
I believe he meant "Doubting Thomas".
Old 02-04-2013 | 07:29 PM
the silver is to block the sun from rotting the fabric. all of this thinning does nothing,,,just use the dope full strength and it will lay out flat with no brush marks. i have covered my full sized stearman and a few cubs and never sanded or thined the do[e. dont use and nitrate. if you apply buterate over nitrate, the bute will shring over the nitrazte and leave what looks just like a mud puddle that dryed up in the sun. when we cover the real planes we use 3 and 4 inch brushes and slater the stuff on when doing flat surfaces. got to be more careful on the sides. some guys try to keep their cubs light so they use only enough to show the color and the "WEAVE" is very evident. this is with ceconite,,,,i have seen full size wings that have way too much buty applyed warp the leading edge and trailing edge as it shrinks over time. i would use silk if i want a "monocoat" finish. the silk will shine up with very few coats ov buty. i recoat the dope in an hour ,,,no need to wait overnight. the only time i ever use thinner is to clean my brushes. i bought 5 gal cans of just about every color aircraft spruce had years ago and have never run out yet and have covered many many models over the years. dope was a lots cheaper 40 years ago. i did leave a cap loose on my can of cleasr and got a skin on top and used a couple quarts of thinner in it and desolved the skin and still use the claer. i give the edges of the wings eetc a double coats of buty and lets it dry and then brush the coverite right thru and make sure i strech the fabric out straight and hold it tight til it drys the proceed arout the rest of the wing etc. i never use nitrate on my models or the full size planes. the sun can rot out silk that isnt protected with silver very fast. aircraft spruce has the silver powder that you can mix with the clear to make your own silver dope . years ago the full sizers used cotton for covering,,of course it is a special cotton made for covering,,,,there was a special ish linen that costs lots more butt would outlasdt the cotton but the ould timers said that the frame work of the airplane needed work way before the linen went bad so the just used the cheaper cotton and would recover every 10 years. those airplanes would be tied down out side and have problems. the lower longerones on the cubs would rot out from rust sometimes.
Old 02-04-2013 | 07:41 PM
ORIGINAL: Zor
ORIGINAL: Rodney
Please correct me if I'm wrong here but: I've been told time and time again that nothing other than butyrate dope can be applied over butyrate dope. You should always use nitrate dope first to stick down the covering and for the first coats to fill the weave. Once you cover with butyrate, you can ONLY use butyrate for any subsequent coats. Can any of you experts either verify this or correct it if wrong?
I do not consider myself an expert but having quite a bit of experience.
I just wish to confirm by experience that you are correct (since you asked).
Some additional knowledge again based on experience _ _ _
Tautening and non-tautening dope is a matter of degree.
Dope labelled non-tautening actually does some tautening.
Labelled tautening has to be applied to strong structures as it can pull considerably and for a long time (decades).
Nitrate has much better adhesion to wood and fabric so it is used first. Stix-it or equivalent is or can be used for gluing the fabric. stix-it is used after the wood has been sealed wth a couple of coats of nitrate dope.
To spray dope it needs lots of dilution like 50 dope and 50 thinner and very thin coats have to be sprayed to avoid pin holes. Pin holes are due to the thinner evaporating, creating bubbles that find their way to the surface. Thin spray coats can avoid that and so can temperature of the environment.
It is best to spray between 60F and 70F (15C to 21C).
Brushed dope can be diluted only about 10% by volume for easy brushing and pin holes rarely developpe at recommended temperature.
Now someone will post that I am polluting the thread with too much information [img][/img] .
Zor
why spay when a good briush with un=thined buterate goes on and speads out like glass ? save the thinners for cleaning the brush. half the dope you spray will be all over everything down wind of the job. all the dope will be on the airplne when you use a brush!
Old 02-04-2013 | 07:59 PM
eddieC's Avatar
<span style="background-color: rgba(255, 255, 255, 0);">It is a good feeling to satisfy our minds. I am just thinking that 100% deterioration of cotton as you originally wrote would result in the cotton falling off in dust (like ashes).
I notice that you have changed your original text which is the text I was suggesting that it needed substantiation or backup.</span>
<div></div><div>Your assumption is wrong.</div><div>The 'strength' being referred to is what's tested with a fabric tester. Fred985 (anyone know what those numbers stand for?) is well-versed in fabric and dope and may have used said tester.</div><div></div><div>I did not change any of my original text. I wrote from memory, then posted a quote from the manufacturer.</div><div></div><div>This is an online hobbyist forum, Zor, not a dissertation exercise. Knock it back a couple notches and we'll get along fine.</div>
Old 02-04-2013 | 10:17 PM
Zor
Banned
ORIGINAL: eddieC
<span>It is a good feeling to satisfy our minds. I am just thinking that 100% deterioration of cotton as you originally wrote would result in the cotton falling off in dust (like ashes).
<div></div><div><u>Your assumption is wrong.</u></div><div>The 'strength' being referred to is what's tested with a fabric tester. Fred985 (anyone know what those numbers stand for?) is well-versed in fabric and dope and may have used said tester.</div><div></div><div><u>I did not change any of my original text</u>. I wrote from memory, then posted a quote from the manufacturer.</div><div></div><div>This is an online hobbyist forum, Zor, not a dissertation exercise. Knock it back a couple notches and we'll get along fine.</div>
Your first text
We have some guys with vintage fabric and dope airplanes from the '60's, and they always have a dirty look to them despite being stored carefully. They look like they were packed in coffee grounds. The fabric is also very brittle. According to full-scale info, polyester fabric loses 85% of its strength within a year if not UV protected, and aircraft cotton loses 100% under the same conditions. The scale interweb forums reference full-scale a lot when talking about covering
Your changed text
Polyester fabric is not as susceptible to this problem as cotton; however, if bare polyester fabric is left in direct sunlight for 12 months it will lose over 85% of its strength. Cotton fabric exposed to the same sunlight for the same period of time will deteriorate almost completely.
Ido not know if Ron Alexander is an employee of the manufacturer.
It remains that unsupported statements are just opinions and not worth more than opinions.
Have a great time and we will not have any problems as I leave this discussion.
Zor
Old 02-05-2013 | 08:13 AM
  #31
FlyingGreg's Avatar
I am rather new to the Koverall process having used it on just one recent project, recovering an old Kadet Senior. I like the fact that once it is tightened with a heat gun it never seems to wrinkle. I stick the fabric down with a couple of coates of nitrate on the bare wood then use more nitrate over the material. Once it dries, the edges are trimmed and stuck with a little more dope. Once everthing is covered and the edges are sealed, a heat gun shrinks it beautifully. Then I brush two to three coates of nitrate to fill the weave, shoot with a rattle can of Krylon primer and then Krylon color. Fuel proof and easy.
Currently just starting on covering another plane with Koverall. What I learned on the first project will be put to good use on this one.
Old 02-05-2013 | 08:30 AM
  #32
Zor
Banned
= fred 985</p>
Zor
Why spray when a good brush with un-thined butyrate goes on and spreads out like glass ? Save the thinners for cleaning the brush. Half the dope you spray will be all over everything down wind of the job. All the dope will be on the airplane when you use a brush!
</p>
fred,</p>
I have never sprayed dope; I use brushes.</p>
Zor
</p>
Old 02-05-2013 | 08:40 AM
  #33
eddieC's Avatar
<span style="background-color: rgba(255, 255, 255, 0);">I do not know if Ron Alexander is an employee of the manufacturer.
Have a great time and we will not have any problems as I leave this discussion.</span>
<div>
</div><div>You are still mistaken, Zor. None of the text has been changed.
<div>
</div><div>I suspect you've found something on the web to prove the statement, Zor, hence your hasty departure. You won't be missed, pal. </div><div>Ron Alexander is a covering expert. The fact he writes the Ceconite how-to speaks to his industry cred IMO. </div></div><div>
</div><div>Sorry to all. Please post how the covering works, as I've yet to try it. I'm doing a Herr Cub in Coverlite and have finished an Retro RC e-Moth in it, and found it easy to use but fragile to storage and hangar rash. </div>
Old 02-05-2013 | 10:49 AM
  #34
Zor
Banned
<span style="color: #0000ff">Blue text inserted by Zor
</span>
ORIGINAL: eddieC
<span>Ido not know if Ron Alexander is an employee of the manufacturer.
<div>
<div>
<span style="color: #0000ff">The texts I posted were highlighted, copied and pasted right off your postings.
</span><font color="#0000ff">You did edit your text and that is the main reason I wish to stop any such discussion with you. </font>
</div><div>I suspect you've found something on the web to prove the statement, Zor, hence your hasty departure. You won't be missed, pal.</div><div>
<span style="color: #0000ff">I certainly will not miss any discussion with you. </span>
Ron Alexander is a covering expert. The fact he writes the Ceconite how-to speaks to his industry cred IMO.</div></div><div>
<span style="color: #0000ff">Ron's unsupported statements were just repeated by you and remain unsupported. They are opinions and not worth more than any unsupported opinions. </span>
Sorry to all. Please post how the covering works, as I've yet to try it. I'm doing a Herr Cub in Coverlite and have finished an Retro RC e-Moth in it, and found it easy to use but fragile to storage and hangar rash.</div>
I can only wish you the best success in your hobby activities and have no further incentive to discuss with you because of your attitude and insistence that you did not change the text of your posting when you actually did.
I would not be surprised that you edited again in case some readers go to verify but I will not bother checking that myself.
Again all the best to you enjoying this fine hobby.
Zor
Old 02-05-2013 | 11:46 AM
  #35
eddieC's Avatar
Zor, <div>What text was changed? I'm mystified. Perhaps we should discuss via PM. </div><div>
</div><div>No one else has noticed any alleged 'changes'. </div>
Old 02-05-2013 | 01:11 PM
  #36
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Sorry guys, I had to step into the thread and remove several posts because one member decided to get into a semantics argument about how things were said here in this thread. I've cleaned up the thread, and  I apologize to those that want to discuss this issue.<div>
</div><div>Ken</div>
Old 02-05-2013 | 02:28 PM
  #37
My Feedback: (109)
It has a nice smell-after being in my shop for awhile that covering job does not look that bad!!!!
Old 02-05-2013 | 06:37 PM
  #38
Zor
Banned
ORIGINAL: PLANE JIM
PLANEJIM,
I do not see any previous postings in this thread from you.
Are you referring to the smell of dope ?
Zor
Old 02-06-2013 | 07:30 AM
  #39
Banned
"It has a nice smell-after being in my shop for awhile that covering job does not look that bad!!!! "
Just don't go out and drive somewhere:-))))))))))))))))
Les
