tape for aileron gap is noisey
Hey guys
My kit told me to add this (like scotch tape) included in the kit for the gap in aileron to avoid flutter that much I get
but now it is making a terrible scratchy noise when I operate them. It is the tape making the noise
How do I solve that problem ??
david
david
MB, CANADA
Hi GBfan,
I usually just use some monocote to seal the gap. I will iron a small strip with the aileron deflected all the way down, that way when the aleron moves it will not be pulling onthe gap filler.
Not sure what to say about the sound you are getting if you can get the tape off without damageing anything maybe you might want to try the monokote gap seal.
Calvi
Calvi
[quote]ORIGINAL: gbfan
Hey guys
david
[/quote
For the record, sealing the control surface gap is not an insurance policy that will keep the surface from flutter. Flutter is a dynamic issue and although sealing the gaps will make the surfaces more effective, it can in fact and has caused flutter because sealing them changes the dynamics of when flutter can occur, and that can be better or worse. So the best insurance to safe guard from flutter is a tight control linkage system and strong servos. Now you can reduce the noise from the sticky tape by just brushing a little light oil on the already installed exposed sticky tape areas.
Bob
Hey guys
david
[/quote
Bob
Taping the gap does not necessarily eliminate flutter, it merrily changes the frequency that it will happen as it makes the ailerons slightly stiffer. The stiffer the aileron structure, the higher the frequency at which flutter will occur. Now, everything will flutter (even an iron bar) if the stimulus is of the proper frequency. The only structure that wil not flutter is one with infinite stiffness and no mass ( a physical impossibility).
Banned
"Taping the gap does not necessarily eliminate flutter,"
But it does eliminate the flutter caused by air flowing thru the gap, around the flying surfaces.
Les
Les
