BUSA 1/4 Scale Fokker Dr 1
#226
My Feedback: (7)
FL
I've finished painting, other than a few touch-ups. So, I decided to post a couple more glamour shots before disassembling her for the rest of the radio install. Got my pilot and one of my Spandau guns on her.
#227
JeffEE,
I like the "scalloped" leading edge sheeting. I often wondered what the purpose of that intertwined tape between the ribs are for?! Maybe you can Shead some light on that for me?
Ray
Ray
#228
If you look at drawings of the full scale design, there is really no structure behind the main spar, holding the ribs together. Unlike many aircraft designs, the trailing edge was just a wire (creating that scallop TE). That interwoven fabric, provided that strength, tying the ribs together. Somewhat like an aft spar.
#229
Vertical,
Thanks for the response. My kit is on it's way along with a GTM cowl. I've got a G38 ready to be set back for that scale look. I'll most likely scallop the LE sheet also. This is a great thread!
Ray
Ray
#230
You are going to have to get really creative on the G38 install. It will not fit right side up. I tried. It may work if you cant it over to like a 45 degree angle. Installing it inverted is not a good option, because you will have to cut the rear landing gear wire in half. This is not a good idea as it really compromises the strength of the gear. You will see when you hold the engine over the plans, while moving it back to where you want it. I think it might be possible, but it will take some creativity.
#231
My Feedback: (7)
FL
Fully assembled. Balanced. Control throws set. Batteries charging. Here are the last pics before she flys. Tomorrow morning the wind is supposed to be down to 2mph. Sounds like Dr.1 weather to me.
I'll report back, good, bad or ugly.
#234
My Feedback: (7)
FL
Maiden flight report: flies great! Very little trim needed. 2 clicks right aileron, 3 clicks down and a bit of right rudder. Practically jumps off the ground. Very stable in the air. Coordinated turns work best. Very gentle stall characteristics. Ground handling was better than I expected. In light wind, I should have no problem taxiing. The only difficulty is the rollout after landing. It wants to turn left, which is not good. I ground looped the first landing. She was slowed down pretty good by that point and no damage was done. I have to hold a decent amount of right rudder after she touches down to keep her point mostly straight. Other than that, she flies great. I have posted video of a takeoff and slow fly-by.
http://youtu.be/K6k6IS9WfJs http://youtu.be/XPLT90JoGko
#239
My Feedback: (7)
FL
Guys, I couldn't resist posting one more pic. Our club has a big fly-in this weekend each year. The weather was great, and I got in three flights with my Dr 1. A friend took an excellent in-flight photo.
I can't believe how good she flies. I fly IMAC and I don't compliment the flight characteristics of many planes, but I'm in love with this one.
#240
AK, did you go with the Dubro wheels or the Williams bros.? I just replaced my Williams bros. with the Dubros, because my bushing plan did not work and I trashed that first set. It was giving me ground handling problems. I am of the opinion that the Dubro wheels are higher quality.
I will be taking my DR1 out to the field tomorrow. I wanna get some flights on her, as I still have less than 10. They sure are fun.
How is the DLE 30 working out? That should be a perfect combo really.
#241
My Feedback: (7)
FL
The DLE 30 is great for the Dr 1. Gobs of power. I fly at 1/4 to 1/3 throttle mostly. The good thing about the DLE 30 is that the model balanced so nicely with it. The bad thing is that it took some time to modify the firewall for the engine. You could get away without rebuilding the firewall by simply cutting a hole and letting the carb stick into the fuse. But, I built in some right and down thrust when I did my firewall, and the plane needs the down thrust.
#242
I found that without the right amount of right thrust, at least with my first one, it would drift to the left at low power settings, making it difficult to line up on final. There are a few tweaks to be made trim wise to get them dialed in. I had a DLE 30 on that first one, and it was a good power choice. I just had a lot of problems with that particular engine, that really gave me fits for the whole season. It was just my engine though. It is the only engine I have ever sent back to get looked at. They replaced the carb, as it was bad. It worked after that.
I actually still have a little issue with my Q35 that I installed. The engine case, where the carb mounts cracked. So it can suck air right there. I JB welded it, but noticed that this joint failed again. My front end is committed to that engine, so I bought another from the Bay. If I have to, I will have to swap engines. The Q 35 is a great engine for this plane though, otherwise. I like the spring start and the mag.
So now that you are all done and you have this great airplane, how do you feel? I always have separation anxiety from the project. I get used to having something to do next. I suppose that is why I always have another project lined up.
Gotta work my little Stab struts tonight a little, but planning to fly mine tomorrow.
#243
My Feedback: (7)
FL
That's the 91" Comp-Arf Extra 300.
As far the the Dr 1 goes, I still have machine guns to mount and cockpit combing to install. I plan on doing the ammo boxes for the guns, putting the step for the pilot and hand holds on the fuse. Still a bit to do. As for a next build??? In a month or two I'll get the itch again and pick out another project. It will be 1/4 scale again. Probably the D 7. I would love to do a GTM 1/3 scale or the BUSA 1/3 Albatros, but I don't have room for them, and I can't transport something that big.
#244
Yah, the Fokker DVII is a great airplane. I plan on taking mine to the Nats this year. It is more stable than the tripe, and way easier on the ground. It builds a the same as the DR1. You will enjoy it a lot. I agree on the 1/3rd scale. It is just too big to handle. Here is a pic of my DVII.
#245
My Feedback: (7)
FL
That's a beautiful D 7. The thing I like about the German WWI planes is the variety of great paint schemes. You can do something really cool looking, and it's scale! Also, the Fokkers don't have a bunch of flying wires that take forever at the field to hook up.
#246
Thank you. That is actually the photo BUSA added to their catalog to advertise the kit.
GTM still sells the 1/4 scale losenge fabric for the DVII . 4 or 5 color. Just like the scale cowl for the DR1, The losenge fabric is the "thing" that I feel makes them much more scale. The original DVII, (other than maybe the first few) were covered overall in losenge fabric. If any other color is seen on them, it was added as a personal marking by the pilot.
This has been a very tough are to duplicate. The GTM fabric is the best thing going though, and I actually got a kick out of using it. It is old school, applied with dope. Somewhat expensive, but worth it IMO.
There are lots of schemes, and a lot of documentation. It is a very fun subject.
On another note, a fellow pilot had one of those NGH 38cc 4 stroke Gas engines at the field today. It worked very well, and would be perfectly suited for the 1/4 scale WW1 models. At my altitude, it would not be enough for the big DVII, but the smaller sopwiths, and Nueports would be great with it.
#247
OK
I just bought a used DR1 and am going to do some mods to it so I need some info on CG for it. Can anybody tell me the CG range? Video of first flight with new radio and smoke install.
Chris
http://youtu.be/M8ztMDSvHyc
Chris
#248
Moderator
Answered at the other post, but here it is again
CG on the Balsa USA 1/4 scale Fokker Triplane (from Dave Lewis at BUSA)
The CG should be 3-5/8” back from the leading edge of the top wing. Start with it at 3-5/8” I don’t care how much weight you have to add to get it there, just get it there.
Then after you’ve flown it and gotten comfortable with it you might want to move it back a little (not to 5”) but a little.
#249
I have a NGH 38 gas four stroke in one of my Balsa USA DVII's, and I find it a bit on the under powered side. It flies the plane sclae, but thats about it. My Saito 2.20 Nitro burner has a LOT more power than the NGH. The NGH is more like a 30 size gas than a 38. But it runs all day on a tank of gas. I am not knocking the NGH, its a nice motor, I just thought I would put my 2 cents in on the subject.
Hey, Vertical G, did you ever get the chance to put the radiator grill from www.iflytailies.com into a plane? I just ordered mine and would like to know how it went. Thanks.
