fuel tank help
MD
I'm building the 1/5 TF Cessna in the kit they have you install a 12oz fuel tank sideway behind the firewall. I mounted a 16oz because I like the extra capacity for the 120 im putting in the plane. However the larger tank won't allow me to run the fuel lines out the center of the firewall in between the engine mount as shown in the kit. Will it be ok if I run the fuel lines let say out through the firewall to the left of the engine mount?
