Reload this Page >
Balsa USA Brotherhood
Old 11-30-2014, 01:47 PM
  #626
vertical grimmace
vertical grimmace's Avatar
Originally Posted by jeffEE
I was looking at pictures of the full size Camel. It appears to have a gap between the wing and fuse. There is also a big amount of dihedral in the bottom wing so a wing tube might not work. More research is needed thats for sure.
Sig sells an aluminum wing mount. You can use this if you have dihedral. I am using this mount system on a giant Stuka. Should solve your problem.
http://www.sigmfg.com/cgi-bin/dpsmart.exe/IndexBuidlingMaterialsEquipmentF.html
For some reason it will not post the direct link to the product. You will have to search the site for wing joiner, under aircraft accessories, then wing mounting.
Old 11-30-2014, 02:33 PM
  #627
ARUP
For 'plug-in' lower wings just epoxy music wire stubs into spars and have brass tubes in fuselage to receive them. The rigging needs to be functional. Then you fabricate a more robust landing gear.
Old 11-30-2014, 04:13 PM
  #628
s3nfo
My Feedback: (14)
blades and sockets work just as well as tubes and you can still do dihedral with Blades.
And just to keep from confusing people when we're all asking questions and talking about wing mounting methods. A 2 piece wing is just like a one piece wing except it's 2 pieces, you still have to bolt the wing to the hole in the middle of the fuse after you put the wing halves together. What you guys wan,t and are talking about are plug in wings.
Old 11-30-2014, 04:23 PM
  #629
vertical grimmace
Essentially, the Sig mounts are "blades". I am actually describing a 3 piece wing in all actuality. Just like how the full scale was done really, except a different mounting method. The last 2 wings I have built are 3 piece. Very handy for these big planes.
Ok, I am attaching some photos. I think for your application, only one mount would be needed per side. I would still add a 1/4" anti rotation pin near the trailing edge though, so it will index properly. The Stuka wing is somewhat complicated to make 3 piece, as it has that inverted gull configuration. You will need to mount your aluminum plate to accommodate your dihedral angle.
ID:	2051319   Click image for larger version
ID:	2051320   Click image for larger version
Old 11-30-2014, 05:50 PM
  #630
spaceworm
Here are pics of my Spacewalker ll with aluminum blade joiners for it's 3 piece wing. The wing center section and LG bolt to the fuse .
Sincerely, Richard
Cub Brotherhood #187; Sig 1/4, H9 100 inch (Gen 1), GB Anniv Cub
Club Saito #635; Saito 56, 100, 120abc, 130T, 180
Kadet Brotherhood #96; Mk 1 Kadet, Kadet Junior,
Sig Kougar, Sig 1/4 Cub, Sig 1/4 Spacewalker II
ID:	2051329   Click image for larger version
ID:	2051330   Click image for larger version
Old 11-30-2014, 05:57 PM
  #631
ANZAC
Hi, I've got six Balsa USA aircraft - a 1/3 scale Pup, a 1/4 scale pup, a 1/4 N-17, 1/4 scale D-V111,1/4 scale DR-1 and a badly wounded D-V11. I would like to join the brotherhood. Regards Col Mitchell
Old 11-30-2014, 06:13 PM
  #632
jwrich
My Feedback: (17)
jwrich's Avatar
I have corresponded with 3136, and Mark does not want manage the Balsa USA Brotherhood thread any more. He ask me to take over the duties and I said I would. If any one has a problem with this, please come forward.
Rich
Old 11-30-2014, 06:17 PM
  #633
ANZAC
I would like to join up. I have several B-USA kits as well as other WW1 aircraft. Any thing to promote WW1 modelling, I'm in. I have been in awe of those WW1 pilots since I was a kid.
Old 11-30-2014, 06:22 PM
  #634
jwrich
My Feedback: (17)
jwrich's Avatar
Welcome ANZAC, looks like you have a full hanger. As keeping with Mark's guidelines please post a picture of your airplanes and post your BUSA Brotherhood number with your signature.
Rich
OK new Balsa USA brother No 1 is Jwrich, over to you now mate.
BUSA brothers
#1 Jwrich OK USA
#2 Jeffo MI USA
#3 ARUP KY USA
#4 RCKen OK USA
#5 mattnew MA USA
#6 surmovik60 VA USA
#7 GerKonig PA USA
#8 Granpooba NY USA
#9 radfordc KS USA
#10 balsa brain FL USA
#11 3136 Victoria Austrialia
#12 wwoneguy MD USA
#13 vertical grimmace CO USA
#14 rcmiket TX USA
#15 bpoates25 FL USA
#16 PiperDriver IL USA
#17 68goat AL USA
#18 jlsimon NJ USA
#19 pat s NC USA
#20 pending IN USA
#21 Steve Percifield IN USA
#22 opol MN USA
#23 Zero TX USA
#24 tonyos VA USA
#25 b206 IL USA USA
#26 LonnieMcc MS USA
#27 eindecer3 TN USA
#28 flyer35 NY USA
#29 jeffEE MN USA
#30 s3nfo CA USA
#31 Kwikfli KS USA
#32 JDHammer PA USA
#33 Ikruse OK USA
#34 bobbailey VA USA
#35 Vampire PA USA
#36 zemkes_wolfpack IN USA
#37 triumphman49 AL USA
#38 SRQFlyer FL USA
#39 Daniel-EL OH USA
#40 hairy46 WY USA
#41 pettit NC USA
#42 Hrannar Iceland
#43 lowbubba OH USA
#45 FokkerD7 OH USA
#44 FireBee VA USA
#46 iampilot2 OH USA
#47 Wagon1 FL USA
#48 darren 4 WI USA
#49 Luxuswaffe FL USA
#50 dryverman VT USA
#51 otterrc FL USA
#52 cooper998 DE USA
#53 lazyace NY USA
#54 wings2an3 NY USA
#55 the pamster TX USA
#56 lucasar15 PA USA
#57 AMA74894 MN USA
#58 squidman TX USA
#59 M_Callahan OH USA
#60 Karp050555 PA USA
#61 optech CA USA
#62 ashby NSW Australia
#63 R/C Art IN USA
#64 on_your_six MD USA
#65 Highflyer2 GA USA
#66 dddaviddean NJ USA
#67 Quagmire CA USA
#68 pending CA USA
#69 ratshooter TX USA
#70 TXAG96 MI USA
#71 R/C Ray NY USA
#72 feep NH USA
#73 sdcranford MO USA
#74 buzzard bait NY USA
#75 chadasmus KY USA (BUSA Team Pilot, Builder and Designer)
#76 fokv25 IN USA
#77 Dynamic! WI USA
#78 WinterHawke WI USA
#79 t6racer NSW Australia
#80 NM2K GA USA
#81 rcjunky67 FL USA
#82 AndyF IN USA
#83 freefall2907 IA USA
#84 a65l VA USA
#85 Grimracer IL USA
#86 Corsair2013 UT USA
#87 Chevelle NY USA
#88 eagledancer FL USA
#89 Leroy Gardner ID USA
#90 ANZAC Australia
Rich
Balsa USA Brotherhood #1
Old 12-01-2014, 01:18 PM
  #635
jeffEE
jeffEE's Avatar
Ok, so it should not be that hard to make a bottom wing change. I have built the 1/3 scale Spacewalker, and understand the set up. Now on to the next area of problem with the build. The ailerons have a gap at the wing tip. As a stand off model it is not a problem. But I think it needs to be looked at. A more scale way of connecting the wing to the aileron is something I want to explore. And thanks for all the great ideas for the wing mods.
Old 12-01-2014, 01:31 PM
  #636
AMA 74894
Moderator
AMA 74894's Avatar
Hey jeffEE! (I met you at the paynesville corn roast this past summer... saw your "prototype" D7 .. very nice work!)
are you thinking something like this for scale aileron hinging?
http://www.largemodelassociation.com...r-scale-model/
about 1/3 the way down the article he's got some scale hinge detailing...
I'm in SUCH a quandary... I can't decide on the BUSA D-7 or DR-1 for my next project... (my Pup is getting close )
Old 12-01-2014, 01:56 PM
  #637
Karp050555
Whether you"re talking 1/4 or 1/3 scale, the DR-1 is the easier build. Have you considered a GTM Fokker D-6? I saw a fellow flying one at MAD and it was impressive.
Old 12-01-2014, 02:02 PM
  #638
flyierjon
Im surprised that no one here yet has mentioned the 1/3rd scale Ercoupe kit by BUSA... Im hoping to purchase this kit in the very near future and came here thinking at least one of you would have build one and could tell me how you liked this kit... but i just went through the whole thread and no ercoupes!!! WOW!! I have owned a full scale ercoupe as i would like to make a twin of it 1/3rd scale size...
anyone have any comments here on this kit????
Old 12-01-2014, 02:40 PM
  #639
AMA 74894
Moderator
AMA 74894's Avatar
actually I didn't even realize GTM makes a D-VI ... I'm thinking his ordering web site might not be fully updated, all he's got is an SE-5 for online ordering right now.
I would certainly consider one... I've been perusing Lou Proctor's site lately too... ooo descisions...
flyierjon.... I've got a couple hundred hours in an old Ercoupe... (full scale) didn't like it. :-/
(of course that may well have been the funky aileron / rudder interconnect) I'd bet the BUSA Kit flies beautifully at any rate.
Old 12-01-2014, 02:53 PM
  #640
Karp050555
You might also want to check out the Ron Weiss plans and short kits from Nick Ziroli. There were at least 6 guys flying 1/3 scale D8's that were built off Ron Weiss plans and maybe a couple of DR-1's from Ron Weiss also. They flew great and were impressive. One day I plan to build Pfaltz DIII from Arizona Modelers. Bruno Stackel, here I come!
Old 12-01-2014, 03:16 PM
  #641
jwrich
My Feedback: (17)
jwrich's Avatar
I don't think I have seen the 1/3 scale Ercoupe in years. When I was in Germany, there two at an event I attended, both looked great & flew very impressive. It is a very old kit. Should you build the kit, I am sure you will get a lot of advice from the forums and the guys at BUSA are a great help. You need to do a construction thread. I think if you call Balsa USA and talk with the tech support folks, they can give you some insight. I built the 1/3 scale Fly Baby Biplane in '82, about the same time frame as the Ercoupe, and it was straight forward construction. As with all BUSA kits you can add as much scale details you want during the build. Maybe some of the other old timers can chimp in.
Rich
BUSA Brotherhood #1
Old 12-01-2014, 03:18 PM
  #642
Karp050555
OK brutha's, I need your opinions. I'm building a BUSA QS Camel. I already have a Snoopy with flying gear but I'm starting to think I might want a Canadian pilot like Dudley Doright or even Horse. So lets have an opinion poll. Snoopy, Dudley, or Horse?
Old 12-01-2014, 03:20 PM
  #643
jeffEE
jeffEE's Avatar
Jim, thanks for the kind words about the V11 prototype. I have built both DVII and DRI's and never thought the DRI was the easy build. But each to their own. I tell all the flyers I meet about the Corn roast. It was truly a nice field and a GREAT bunch of people. ( darn good food also). I just e-mailed Proctor about a DVII kit. He said that he builds each kit after its ordered and it takes about 10 weeks to get one done. But boy oh boy they are the cream of the crop!
Karp050, Arizona Models....I have never read a good comment about their kits. Again, each to their own. Perhaps you will have better luck than others and its true that there are 1000 bad comments for every good one. The Pfaltz is a nice airframe with lots of colors to pick from. Perhaps a build thread if you go that route?
Old 12-01-2014, 03:22 PM
  #644
jeffEE
jeffEE's Avatar
I vote Dudley Do Right. There will be thousands of Dogs. JMO.
Old 12-01-2014, 04:15 PM
  #645
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
RCKen's Avatar
I would love to build a Ercoupe one day, but the price tag on it keeps it in my "want" list instead of on my "on the shelf" list. Someday I'll hopefully have one though.
Ken
Old 12-01-2014, 04:38 PM
  #646
vertical grimmace
If GTM does not list an item on his site, then it is not available. Unfortunately, he has all but dropped his entire product line.
Old 12-01-2014, 05:39 PM
  #647
s3nfo
My Feedback: (14)
Rich
Good on ya Rich, thanks for stepping up.
Old 12-01-2014, 05:59 PM
  #648
jwrich
My Feedback: (17)
jwrich's Avatar
Thanks Jerry, Thought I would since Mark ask.
Rich
Old 12-01-2014, 06:02 PM
  #649
jwrich
My Feedback: (17)
jwrich's Avatar
Krup, what is about "Horse"?
Old 12-01-2014, 06:39 PM
  #650
Karp050555
Dudleys horse was named "Horse".
