Balsa USA Brotherhood
#1203
I like E6000 for a lot of things also. One advantage of the RC-56 is it is water cleanup (until dry)
#1208
I had heard it was to wipe the oil off their goggles because the rotary engines had no exhaust systems since the engine spun with the prop and the exhaust came back straight into their faces. Sometimes I think the WWI airplanes were designed to make the pilot as uncomfortable as possible if they didn't kill him.
#1211
Personally I like to run a tank that only has enough fuel for about 15 minutes max ...
I had a friend that lost a 104 inch Corsair because he had a huge gas tank and the throttle stuck at too high of a setting to land.. Unfortunately he ran out of receiver battery before fuel and the plane was destroyed. there are other options like kill switches obviously..
I seldom fly longer than ten minutes a flight, and plan on it running out 3-5 minutes after that.
It all depends on your personal taste, but that is the way I pick a tank. I usually run them on test stands so I see about how long they will run on the test stand.
#1213
My Feedback: (17)
I use 16 oz. tanks because I more of them. Most of my airplanes are 1/4 scale and need the weight in the nose using G-38, G-26 and DLE 35. I recommend, what ever tank use, you should fly your normal flight pattern, let's say 12 min. Then start your clock, gain some altitude over the field, make others aware what you are doing, then fly until you are out of gas. This will give a base line to set your timer. Works for me!
Fair Winds & Happy Flyin'
Rich
Rich
#1215
My Feedback: (17)
Monsour, I think you want to become a member of the BALSA USA Brotherhood. It is customary to post pictures of you BUSA models and share your experiences with them. As you have read on this thread, we all enjoy sharing and adding helpful advice. You are number 123, a first name is always helpful.
It would be helpful for me if all BUSA Brothers would post their BUSA Brotherhood number in their signature. If I have missed anyone please let me know.
BUSA brothers
#1 jwrich, Enid, OK, USA
#2 Jeffo New Baltimore, MI, USA
#3 ARUP KY USA
#4 RCKen Lawton, OK, USA (RCU Forum Manager/Admin)
#5 mattnew, Haverhill, MA, USA
#6 surmovik60 VA USA
#7 GerKonig, Levittown, PA, USA
#8 Granpooba, Queensbury, NY, USA
#9 radfordc, Lansing, KS, USA
#10 balsa brain, Jacksonville, FL, USA
#11 3136 Victoria Austrialia **
#12 wwoneguy, Beltsville, MD, USA
#13 vertical grimmace, Ft. Collins, CO, USA
#14 rcmiket, El Paso, TX, USA
#15 bpoates25, Riverview, FL, USA
#16 PiperDriver, Rolling Meadows, IL, USA
#17 68goat Alabaster, AL, USA
#18 jlsimon, Long Valley, NJ, USA
#19 pat s, Candor, NC, USA
#20 pending IN USA
#21 Steve Percifield, Noblesville, IN, USA (Sir Percy)
#22 opol, Two Harbors, MN, USA
#23 Zero, Houston, TX, USA
#24 tonyos, Madison Heights, VA, USA
#25 b206, Opdyke, IL, USA
#26 LonnieMcc, Carriere, MS, USA
#27 eindecer3, McMinnville, TN, USA
#28 flyer35, Ilion, NY, USA
#29 jeffEE, Farnington, NM, USA
#30 s3nfo, San Diego, CA, USA
#31 Kwikfli, Winfield, KS, USA
#32 JDHammer, Slippery Rock, PA, USA
#33 Ikruse, Lawton, OK, USA
#34 bobbailey, Chesapeake, VA, USA
#35 Vampire, Bath, PA, USA
#36 zemkes_wolfpack, Winamac, IN, USA
#37 triumphman49, Decatur, AL, USA
#38 SRQFlyer, Sarasota, FL, USA
#39 Daniel-EL, Maumee, OH, USA
#40 hairy46, Sinclair, WY' USA
#41 pettit, Durham, NC, USA
#42 Hrannar, Patrekfjordur, Iceland **
#43 lowbubba, Miamisburg, OH, USA
#45 FokkerD7, Cable, OH, USA
#44 FireBee, Chesapeake, VA, USA
#46 iampilot2, Middletown, OH, USA
#47 Wagon1,Penscola, FL, USA
#48 darren 4, Eau Claire, WI, USA
#49 Luxuswaffe, Hialeah, FL, USA
#50 dryverman, West Rutland, VT, USA
#51 otterrc FL USA
#52 cooper998, Newark, DE, USA
#53 lazyace, Buffalo, NY, USA
#54 wings2an3 Monroe, NY, USA
#55 The Pamster, Dallas, TX, USA
#56 lucasar15, Pottsville, PA, USA
#57 AMA74894, Spicer, MN, USA (Moderator Jim Buzzeo)
#58 squidman, Waco, TX, USA
#59 M_Callahan, South Lebanon, OH, USA
#60 Karp050555, Philadelphia, PA, USA
#61 optech, San Diego, CA, USA
#62 ashby NSW Australia **
#63 R/C Art, Shelbyville, IN, USA
#64 on_your_six MD USA
#65 Highflyer2, Alpharetta, GA, USA
#66 dddaviddean NJ USA
#67 Quagmire, Costa Mesa, CA, USA
#68 pending CA USA
#69 ratshooter, Burleson, TX, USA
#70 TXAG96, Augusta, MI, USA
#71 R/C Ray, Valley Cottage, NY, USA
#72 feep, Pelham, NH, USA
#73 sdcranford, Willard, MO, USA
#74 buzzard bait, Ithaca, NY, USA
#75 chadasmus, Freedom WI, USA, (BUSA Team Pilot, Builder and Designer)
#76 fokv25, Westfield, IN, USA
#77 Dynamic, Stratford, WI, USA
#78 WinterHawke, Waukesha, WI, USA
#79 t6racer NSW Australia **
#80 NM2K, Ringgold, GA, USA
#81 rcjunky67, Belleview, FL, USA
#82 AndyF Ft. Wayne, IN, USA
#83 freefall2907, Ottumwa, IA, USA
#84 a65l, Virginia Beach, VA, USA
#85 Grimracer, Urbana, IL, USA
#86 Corsair2013, Granytsville, UT, USA
#87 Chevelle NY USA
#88 eagledancer, Orlando, FL, USA
#89 Leroy Gardner ID USA
#90 ANZAC Australia **
#91 Spadsriver09, Southbend, IN, USA
#92 PSB, Malven, OH, USA
#93 bradpaul, Apopka, FL, USA
#94 MRadu, Los Gatos, CA, USA
#95 HorsePowerAviation, Cincinnati, OH, USA
#96 Shoestring, Granite, MN, USA
#97 David Gladwin, CookhamBerkshire, United Kingdom **
#98 Rich6170, Springfield, OH, USA
#99 Wildbills21, Menominee, MI, USA, (Team BUSA, pilot, builder,& chief mechanic)
#100 Rickj, Akron, OH, USA
#101 Geezeraviation, Houston, TX, USA
#102 Flyboy077, Uniontown, OH, USA
#103 Shelstrm, Lancaster, WI, USA
#104 Drude, North Port, FL, USA
#105 bschatz, West Hills, CA, USA
#106 RCDuffer, Valley Center, CA, USA
#107 capnpaul, Orillia, ON, Canada **
#108 p38nut, Indianapolis, IN, USA
#109 yoda64, Bloxon, VA, USA
#110 Jaybird, Hallowell, ME, USA
#111 mbnt, IL, USA
#112 Foodstick (Lance), Ankeny, IA, USA
#113 adec, Perthaustralra, Australia **
#114 Navy, Orange Park, FL, USA
#115 RD Jeff, Anchorage, AK, USA
#116 Mistral 12, Granbury, TX, USA
#117 JKEpps, Greenbelt, MD, USA
#118 FlyerInOKC, Okla, City, OK, USA
#119 PT19, Buna, TX, USA
#120 Jim Scott, ?
#121 Srecker, Erie, PA, USA
#122 bigbird3, Williamstown, VT, USA
#123 Monsour, Fisherville, KY, USA
Fair winds and happy flyin'
Rich
BUSA brothers
#3 ARUP KY USA
#20 pending IN USA
#51 otterrc FL USA
#68 pending CA USA
#87 Chevelle NY USA
#111 mbnt, IL, USA
#120 Jim Scott, ?
Rich
#1219
My Feedback: (17)
Welcome to the Brotherhood, Mark. Nice plane, you will love flying it. Please post more pictures as you finish the Neiuport.
Good luck on the maiden flight.
Rich
BUSA brothers
#3 ARUP KY USA
#20 pending IN USA
#51 otterrc FL USA
#68 pending CA USA
#87 Chevelle NY USA
#111 mbnt, IL, USA
#120 Jim Scott, ?
#124 Marksp, Redmond, WA, USA
Rich
Rich
BUSA brothers
#3 ARUP KY USA
#20 pending IN USA
#51 otterrc FL USA
#68 pending CA USA
#87 Chevelle NY USA
#111 mbnt, IL, USA
#120 Jim Scott, ?
Rich
#1221
My Feedback: (38)
Here is my latest Balsa USA model ....... a work in progress.
There sure are a lot of pieces and parts to cover.
All the wings and tail pieces are covered and rib stitched and ready for paint.
I still have the fuse to cover.
This is the color scheme I have chosen..... the green one. It is an early DVII - I like the Maltese crosses.
#1223
My Feedback: (38)
Hi Rich
Yes. I test fit Greg Hahn's DVII fuselage last fall at a fly-in - - - before he stuck it into his trailer I slipped it into the back of my Dodge mini-van and it fit like a glove!
Oh and I didn't have time to build it...... Greg built it for me .....we did a little trading.
A bigger transport for my planes - I wish - but I don't think that is going to happen.
Cheers,
Art
Cheers,
Art
