Reload this Page >
Balsa USA Brotherhood
Old 03-12-2017, 02:41 PM
  #1576
smkrcflyer
smkrcflyer's Avatar
Thanks for the feedback on the L4.
Old 03-12-2017, 06:04 PM
  #1577
spaceworm
Originally Posted by s3nfo
And I think the L-4 version fly's better than the Cub version.
Just curious, why do you think the L4 would fly any better than the J3? Same fuse except for the greenhouse, same engine, same wing, same weight? UNless there are differences that I am not aware of? Many L4 are made from J3 and vice versa. Both full scale and models. Just asking for my own education. Thanks.
Old 03-13-2017, 02:47 PM
  #1578
s3nfo
My Feedback: (14)
Don't know why, but I've flown both and built by several different builders and I always think the L-4 version flys better.
Old 03-14-2017, 09:04 AM
  #1579
TomCrump
TomCrump's Avatar
I think the difference is in the pilot's perception.
For instance, I always think that Cubs, with wheel pants, fly better than those without.
I haven't decided on which way I will follow on my BUSA Cub.
ID:	2205282   Click image for larger version
Old 03-15-2017, 08:03 AM
  #1580
FlyerInOKC
FlyerInOKC's Avatar
An interesting discussion.
Old 03-15-2017, 12:00 PM
  #1581
foodstick
foodstick's Avatar
Yellow cubs run hot and cold here... You will see SO MANY for awhile you tire of them..and then you won't see them at all. So possibly that figures in to the perceived difference?
Old 03-17-2017, 07:22 AM
  #1582
radfordc
My Feedback: (14)
radfordc's Avatar
For sale....BUSA SPAD X-III ready to fly. I have too many planes and need to thin the herd a bit. This plane is ready to fly with a USA 41 engine and all servos installed. It has flown many times and is a great flyer. $650 You will have to pick up the plane in Lansing, KS (near Kansas City).
Name:	BUSA SPAD X-III.JPG
ID:	2205751   Click image for larger version
ID:	2205752   Click image for larger version
ID:	2205753   Click image for larger version
ID:	2205754   Click image for larger version
ID:	2205755   Click image for larger version
Old 03-17-2017, 01:57 PM
  #1583
jwrich
My Feedback: (17)
jwrich's Avatar
Charlie, if I didn't already have one, I would buy yours. I can understand thinning out your fleet, but why the Spad? I know it is a great flying airplane, someone is going to get a good deal. It flew great every time I saw it fly.
Do you think you can come to our Okie Dawn Patrol in July? We had several pilots, many airplanes and we did fly at dawn. It is a little strange taking off in the dark. The weather was great, lots of fun!!
Wind Winds & Happy Flyin'
Rich
Old 03-17-2017, 02:08 PM
  #1584
radfordc
My Feedback: (14)
radfordc's Avatar
The SPAD is for sale because it takes twice as long to put together as the Nieuport 28....so it never seems to make it to the field. I may be able to make it to Guthrie this year for either the big bird or the dawn patrol. Are you going to Eureka Springs?
Old 03-17-2017, 02:39 PM
  #1585
jwrich
My Feedback: (17)
jwrich's Avatar
I do plan on going to Eureka Springs, I think the wife may go with me. Got a question. did you move the balance of your spad forward, if so how much. Jim Suchy, who built the the 1/4 and then designed the 1/3 scale, said on the 1/4 scale the cg should be moved forward. I am just not comfortable fly my Spad, thinking about adding a little more weigh in the nose.
Rich
Old 03-17-2017, 06:43 PM
  #1586
radfordc
My Feedback: (14)
radfordc's Avatar
Rich
When I built the plane I added a couple of pounds of lead to the nose. Flying showed that it was too nose heavy. I eventually took all the lead out.
Here is what I said when I did the W&B, "I did the weight and balance today using a Vanessa rig. Even with the big hunk of engine the plane was still somewhat tail heavy. The plans call for 4.25" back from the LE. I needed a couple of pounds of lead to get it to that mark. However, the total weight is still under 19 lbs according to my "not so digital" scale.
Here is what I wrote about the plane after the first few flights, "After 4 flights I'm very pleased with how she flys. I took all the lead out of the nose and now she flys much better. I think the CG shown on the plans is far to forward for good flying. With a 10 mph headwind the takeoff roll was less than 20 feet. Rolls are "scale-like"...somewhat slow and requires a dive and pull up to look right. Multiple loops are easy from level flight. Snap rolls and spins start and stop with no problem. Landings are slow and easy. I think I can move the batteries behind the wings and make it even better. "
Charlie
Old 03-17-2017, 06:48 PM
  #1587
radfordc
My Feedback: (14)
radfordc's Avatar
Here is a flight video after removing the nose weight.
https://youtu.be/MbSWYMhenjg
Old 03-17-2017, 08:18 PM
  #1588
jwrich
My Feedback: (17)
jwrich's Avatar
So, how far back from 4.25 did you go and not be tail heavy? Did you go back a 1/2, 3/4, 1 or more. I really want to get this one flying where I can enjoy it as much as I do the Fokker D-VII. I used the Vanessa rig, set it at 4.25 from the leading edge. I think I'll this weekend Ok? when would good for you?
Rich
Old 03-18-2017, 07:40 AM
  #1589
radfordc
My Feedback: (14)
radfordc's Avatar
I'm not sure how far back the CG is. After the initial W&B I just kept taking a little weight out of the nose until the plane was flying good.
Old 03-18-2017, 08:37 AM
  #1590
jeffEE
jeffEE's Avatar
JWRich, in a post you said that Jim Suchy, drew up 1/3 scale plans for the SPAD? Is there any way to get a copy? I keep asking Balsa USA about their big SPAD and they keep telling me they are not kitting a 1/3 scale SPAD. It would look great setting next to my DRI. Oh and where can I see more about this Okie Dawn Patrol in July? Thanks for any information.
Old 03-18-2017, 12:35 PM
  #1591
jwrich
My Feedback: (17)
jwrich's Avatar
Jeff, go to RCSCALE BUILDER.COM. in the forum section, Scrach Builds, page 4, SPAD XIII 1/3 scale, Tmoth.
If you are not a member you can register as a guest to view the site, however you are limited to 5 posts. Membership is $20.00 a year, it is worth every penny. Lots of great builders that pass on multitudes of information.
Jim does sell his plans and some of the special FG parts and if you do a construction thread on RCB, he will he watching. Great guy, very talented.
Old 03-18-2017, 02:28 PM
  #1592
av8ter
My Feedback: (33)
Add me to the Balsa USA brotherhood please. 1/3 scale Fokker D-VII and 1/3 scale J-3 cub.
Old 03-18-2017, 04:31 PM
  #1593
jwrich
My Feedback: (17)
jwrich's Avatar
Welcome Larry, I'll assign you a number. If would please post picture of your plane, we all would like to see them. I haver the Fokker D-VII and the Pipe Cub, both are 1/4 scale. I am not sure where Dickinson TX, is but you may be interested in attending our Okie Dawn Patrol in July. It is the next weekend after the 4th July holiday in Guthrie. We do fly at dawn. I will post more about it as time draws near. Again Welcome and post often we like to hear about folks from around the country and world.
It would be helpful for me if all BUSA Brothers would post their BUSA Brotherhood number in their signature. If I have missed anyone please let me know.
Balsa USA Brothers
#1 jwrich, Enid, OK, USA
#2 Jeffo New Baltimore, MI, USA
#3 ARUP KY USA
#4 RCKen Lawton, OK, USA (RCU Forum Manager/Admin)
#5 mattnew, Haverhill, MA, USA
#6 surmovik60 VA USA
#7 GerKonig, Levittown, PA, USA
#8 Granpooba, Queensbury, NY, USA
#9 radfordc (Charlie), Lansing, KS, USA
#10 balsa brain, Jacksonville, FL, USA
#11 3136 Victoria Austrialia **
#12 wwoneguy, Beltsville, MD, USA
#13 vertical grimmace, Ft. Collins, CO, USA
#14 rcmiket, El Paso, TX, USA
#15 bpoates25, Riverview, FL, USA
#16 PiperDriver, Rolling Meadows, IL, USA
#17 68goat Alabaster, AL, USA
#18 jlsimon, Long Valley, NJ, USA
#19 pat s, Candor, NC, USA
#20 pending IN USA
#21 Steve Percifield, Noblesville, IN, USA (Sir Percy)
#22 opol, Two Harbors, MN, USA
#23 Zero, Houston, TX, USA
#24 tonyos, Madison Heights, VA, USA
#25 b206, Opdyke, IL, USA
#26 LonnieMcc, Carriere, MS, USA
#27 eindecer3, McMinnville, TN, USA
#28 flyer35, Ilion, NY, USA
#29 jeffEE, Farnington, NM, USA
#30 s3nfo, San Diego, CA, USA
#31 Kwikfli, Winfield, KS, USA
#32 JDHammer, Slippery Rock, PA, USA
#33 Ikruse, Lawton, OK, USA
#34 bobbailey, Chesapeake, VA, USA
#35 Vampire, Bath, PA, USA
#36 zemkes_wolfpack, Winamac, IN, USA
#37 triumphman49, Decatur, AL, USA
#38 SRQFlyer, Sarasota, FL, USA
#39 Daniel-EL, Maumee, OH, USA
#40 hairy46, Sinclair, WY' USA
#41 pettit, Durham, NC, USA
#42 Hrannar, Patrekfjordur, Iceland **
#43 lowbubba, Miamisburg, OH, USA
#45 FokkerD7, Cable, OH, USA
#44 FireBee, Chesapeake, VA, USA
#46 iampilot2, Middletown, OH, USA
#47 Wagon1,Penscola, FL, USA
#48 darren 4, Eau Claire, WI, USA
#49 Luxuswaffe, Hialeah, FL, USA
#50 dryverman, West Rutland, VT, USA
#51 otterrc FL USA
#52 cooper998, Newark, DE, USA
#53 lazyace, Buffalo, NY, USA
#54 wings2an3 Monroe, NY, USA
#55 The Pamster, Dallas, TX, USA
#56 lucasar15, Pottsville, PA, USA
#57 AMA74894, Spicer, MN, USA (Moderator Jim Buzzeo)
#58 squidman, Waco, TX, USA
#59 M_Callahan, South Lebanon, OH, USA
#60 Karp050555, Philadelphia, PA, USA
#61 optech, San Diego, CA, USA
#62 ashby NSW Australia **
#63 R/C Art, Shelbyville, IN, USA
#64 on_your_six MD USA
#65 Highflyer2, Alpharetta, GA, USA
#66 dddaviddean NJ USA
#67 Quagmire, Costa Mesa, CA, USA
#68 pending CA USA
#69 ratshooter, Burleson, TX, USA
#70 TXAG96, Augusta, MI, USA
#71 R/C Ray, Valley Cottage, NY, USA
#72 feep, Pelham, NH, USA
#73 sdcranford, Willard, MO, USA
#74 buzzard bait, Ithaca, NY, USA
#75 chadasmus, Freedom WI, USA, (BUSA Team Pilot, Builder and Designer)
#76 fokv25, Westfield, IN, USA
#77 Dynamic, Stratford, WI, USA
#78 WinterHawke, Waukesha, WI, USA
#79 t6racer NSW Australia **
#80 NM2K, Ringgold, GA, USA
#81 rcjunky67, Belleview, FL, USA
#82 AndyF Ft. Wayne, IN, USA
#83 freefall2907, Ottumwa, IA, USA
#84 a65l, Virginia Beach, VA, USA
#85 Grimracer, Urbana, IL, USA
#86 Corsair2013, Granytsville, UT, USA
#87 Chevelle NY USA
#88 eagledancer, Orlando, FL, USA
#89 Leroy Gardner ID USA
#90 ANZAC Australia **
#91 Spadsriver09, Southbend, IN, USA
#92 PSB, Malven, OH, USA
#93 bradpaul, Apopka, FL, USA
#94 MRadu, Los Gatos, CA, USA
#95 HorsePowerAviation, Cincinnati, OH, USA
#96 Shoestring, Granite, MN, USA
#97 David Gladwin, CookhamBerkshire, United Kingdom **
#98 Rich6170, Springfield, OH, USA
#99 Wildbills21, Menominee, MI, USA, (Team BUSA, pilot, builder,& chief mechanic)
#100 Rickj, Akron, OH, USA
#101 Geezeraviation (Doc), Houston, TX, USA
#102 Flyboy077, Uniontown, OH, USA
#103 Shelstrm. The other Doc), Lancaster, WI, USA
#104 Drude, North Port, FL, USA
#105 bschatz, West Hills, CA, USA
#106 RCDuffer, Valley Center, CA, USA
#107 capnpaul, Orillia, ON, Canada **
#108 p38nut, Indianapolis, IN, USA
#109 yoda64, Bloxon, VA, USA
#110 Jaybird, Hallowell, ME, USA
#111 mbnt, IL, USA
#112 Foodstick (Lance), Ankeny, IA, USA
#113 adec, Perthaustralra, Australia **
#114 Navy, Orange Park, FL, USA
#115 RD Jeff, Anchorage, AK, USA
#116 Mistral 12, Granbury, TX, USA
117 JKEpps, Greenbelt, MD, USA
#118 FlyerInOKC, Okla, City, OK, USA
#119 PT19, Buna, TX, USA
#120 Jim Scott, ?
#121 Srecker, Erie, PA, USA
#122 bigbird3, Williamstown, VT, USA
#123 Monsour, Fisherville, KY, USA
#124 Marksp (Mark), Redmond, WA, USA
#125 Quidleywins , Kyneton Victoria, Australia**
#126 M.Casper (Michael), Perry, IO, USA
#127 Twin_Flyer (Bill), Westhampton Beach, NY, USA
#128 Big Stikflyer (Jay), Machesney, IL, USA
#129 SkinnyBob (Bob), Park Falls, WI, USA
#130 Jetset, (Myles), Picton, ON, Canada**
#131 John Taylor, Macedon, NY, USA
#132 dwreel (Dick), Southern Pines, NC, USA
#133 jimbrock (Jim), Houston. TX, USA
#134 Bandit59, Irmo, SC, USA
#135 Check6, (Fred), N.Scituate, RI, USA
#136 OldScaleGuy, (Steve), Seymour, IN, USA
#137 N1EDM, (Bob), Brockton, MA, USA
#138 Str8aero, (Lee), Sheridan, WY, USA
#139 SAProbuster, (Bob), San Antonio, TX, USA
#140 TomCrump, (Tom), Traverse City, MI, USA
#141 spaceworm, (Richard), Guilford, CT, USA
#142 a8ter, (Larry), Dickinson, TX, USA
Fair Winds & Happy Flyin'
Rich
Old 03-18-2017, 04:35 PM
  #1594
jwrich
My Feedback: (17)
jwrich's Avatar
Dang site is messing up again. I'll edit my last post again later
Rich
Site still messed up 3/20/17 Rich
Old 03-19-2017, 04:31 AM
  #1595
rcmiket
rcmiket's Avatar
"Membership is $20.00 a year, it is worth every penny. Lots of great builders that pass on multitudes of information."
Best 20 bucks I've ever spent.
Mike
BUSA Brotherhood #14
Old 03-19-2017, 04:54 AM
  #1596
TomCrump
TomCrump's Avatar
Mike
I'm a Charter Member and a lifetime supporter.
There's a lot of good scale building info on RCSB.
Old 03-19-2017, 06:06 PM
  #1597
jwrich
My Feedback: (17)
jwrich's Avatar
Jeff, I forgot to answer your question about the Okie Dawn Patrol. It is held at the Sooners Squdron field in Guthrie, Okla, which about 40 miles north of OKC. I am not sure where Farmington, MN is or how far it is from us. You can find out information on these sites, soonerssqudron.org click on OKSS Events scroll down to July and you can open the flyer for the event. Also, you can go to the tulsagluedobbers.com, click on pic/video, scroll down to Guthrie Dawn Patrol 2016, there are several pictures. If you scroll down to video open it then scroll down to Dawn Flight at 2015 Oklahoma. I hope you can find all of this. We do have a lot of fun at this event, damn, no one got many pictures and or video of the 2016 event. I thought someone else was taking the pictures, we were all flying.
If you have any questions, just ask .
Rich
Old 03-20-2017, 12:31 PM
  #1598
jeffEE
jeffEE's Avatar
So the video shows that you really do not have a Dawn patrol. You have a PRE dawn - Dawn patrol. Man it was dark when they started flying! I may have to drive down and join you.
Old 03-21-2017, 07:24 AM
  #1599
FlyerInOKC
FlyerInOKC's Avatar
Bring a wide brim straw hat you'll be glad you did! Downtown Guthrie is very historic being the original Territorial Capital so if the Mrs./significant other other comes there is plenty to interest her if she is less interested in the Patrol. There is also a great BBQ place next to I35 at one of the main Guthrie exits.
Old 03-24-2017, 03:44 AM
  #1600
Quigleywins
Quigleywins's Avatar
Default Sopwith Pup
Well its HO HO and off to work we go All ready to lay some Glue over the weekend. Not a great time to start,Weather is perfect fo flying, The Australian Formula F1 is on in Melbourne on Sunday And Twins and More are at the State flying field all day Sunday.I will do a Builds thread in Kit Builds,start when the glue is running in the Vains.
Name:	IMG_3850 (600x400).jpg
